megi
Post by megi on Nov 17, 2011 5:24:14 GMT -5
Hi folks, just thought it might be useful for me to post some pictures of my soldering/wiring skills (or lack of them possibly... ) - I have done a few guitar wiring jobs over about the past couple of years, at the beginning of which I was a complete novice in terms of electronics and practical wiring/soldering. My knowledge of electronics is still pretty limited, and has some massive holes I'm sure - the soldering has got better with practice, though I still feel I may not be doing things quite in the "approved way" (whatever that is...). Anyway, I've just finished wiring John H's "Strat SP" circuit for a strat build project (waiting for the other parts to arrive now!), so thought I'd put up some pics of the job for you all to look at - any comments or advice gratefully received, and thanks for your time, cheers!
Post by newey on Nov 17, 2011 5:56:21 GMT -5
megi-
Your soldering looks fine. But, please, either downsize those pics or run them vertically rather than horizontally as we now have to scroll horizontally to see them.
Thanks!
megi
Post by megi on Nov 17, 2011 6:03:24 GMT -5
megi- Your soldering looks fine. But, please, either downsize those pics or run them vertically rather than horizontally as we now have to scroll horizontally to see them. Thanks! Apologies newey - post ammended, hope that's working better now? For some reason on my computer they were scrolling vertically anyway so I didn't realise the problem.
Post by newey on Nov 17, 2011 6:28:41 GMT -5
Thanks, much better now! We try to avoid horizontal scrolling, not everyone uses a widescreen monitor.
Post by 4real on Nov 17, 2011 12:42:21 GMT -5
Excellent neat work there megi, nice shiny joins and even insulation where needed and you have kept the super-switch wiring nice a low so everything should fit in ok and not 'short' which is a fault of many a wire.
If by chance the switch does 'bottom out' into a shielded cavity, for precautions sake, it can be a good idea to cover that area under it with a bit of PVC tape or similar just in case...well, I've found.
Great work, well done
Post by JohnH on Nov 17, 2011 14:26:12 GMT -5
It does look like nice work. Looking forward to hearing how it all sounds when its done!
megi
Post by megi on Nov 17, 2011 15:16:25 GMT -5
Cheers guys, I guess I'm OK how I do things then - probably I just wanted to know that the results I'm getting look something like those you would expect for a circuit like this. I do try to keep things as neat as I can -so having a "spaghetti junction" of wires like this in the control cavity is not unusual?
I'm very keen to find out how it sounds too John - I'll be sure to post again when I get to that point.
megi
Post by megi on Nov 17, 2011 15:55:12 GMT -5
Beauty is in the eye of the beholder, but I just thought I'd show you the other side of the pickguard, for what it's worth!
