bonnerik
Post by bonnerik on May 9, 2012 18:15:07 GMT -5
i've got quite a bit of spare space in my cavity, rgith now only sporting a tone, 5 way switch and a volume control. i wonder if any of you guys know something cool i could add ? i thought of a killswitch, but if there are other stuff i want to know about em!
Post by yakkmeister on May 9, 2012 21:55:21 GMT -5
Killswitch sounds good ...
Usual options (depending on the pups) like: Phase switch Parallel/series switching Bypass/solo switch sub-miniature hamsters powering an analogue lfo synth
Post by sbgodofmetal on May 10, 2012 18:42:55 GMT -5
You could Try adding this, www.stewmac.com/shop/Electronics,_pickups/Onboard_electronics_and_preamps/EMG_Afterburner.html Although you would need to add a new battery cavity, unless you got enough space in the cavity to fit the battery too.
