catflaps
Post by catflaps on Jul 19, 2012 4:36:04 GMT -5
I have an EMG 81/85 set in my Westone Spectrum guitar that I think may be faulty. When I try to play it through any solid-state amp, my Marshall MG250 or small practice amp, I just get a loud buzzing and absolutely no response in the strings. Touching the pickups will make the buzzing louder. The guitar works with my old Jansen 6/20 tube amp and also if I plug straight into the line-in on my computer, though the tone is dull and muted, and the tone/volume pots don't seem to do anything (it's as loud with the volume up as down). If I try to use any effects pedals, wah, distortion, whatever, I get the same total lack of response as with the solid state amp.. I though it might be a wiring issue and tried several different wiring configurations, even bought a new wiring kit and pots, but the problem still persists. What might the problem be? Is there any way to fix this, or are they screwed. Thanks in advance Yes, I have tried changing the battery
Post by reTrEaD on Jul 19, 2012 7:02:29 GMT -5
If it was just one pickup, I'd suspect the pickup. But since it's two, I'd suspect something in common. Since you already checked the battery, look for a problem in the wiring. Either the battery wiring or something in common between the two pickups, like the ground circuit.
