Post by ring0 on Sept 6, 2012 9:59:55 GMT -5
Hello all. Long time reader, first time poster.
I'm having a no sound issue that I am unable to troubleshoot. I have some presumptions as to where I've buggered up the wiring on this guitar but I'd like an expert's opinion before I recommence surgery.
About me: I have soldering and electronics experience. I researched for five weeks before committing to this project - Figured I'd actually do something with all that I'd learned.
What I'm trying to do:
My guitar is a Yamaha Pacifica 112 CPJ - One humbucker, two singles, one volume pot, one tone pot, mono output jack.
After having it for many years I wanted to improve my sound options, as well as the guitar itself. I did some physical work on the guitar (aligning neck, paint touch-up, general maintenance) before getting to the bulk of my project: the electronics.
The electronics that came as stock weren't of a great quality. Took 'em all out. Wires weren't soldered cleanly and long stretches of braid criss-crossed around the cavity. No treble bleed circuit. Lastly the guitar had the standard small piece of foil on the pickguard's corner as shielding.
Replaced with better quality parts:
* Volume: CTS 500k Audio Push/Pull (DPDT) Pot.
- Treble bleed circuit: .001uF Orange Drop Cap in parallel with a 130k resistor.
* Tone: Burns 500k Audio no-load Pot.
- Tone Cap: CDE Film .022uF Cap.
* Switch: StewMac Super Switch (4-pole, 5-throw) .
* Output Jack: Switchcraft 1/4" Stereo Jack.
My overall scheme involves applying quality shielding & grounding (as per the Shielding a Strat instructions), modify the humbucker from two-conductor to four-conductor, followed by unmounting the stock electronics and putting in the new ones. I then want to do the Mike Richardson wiring and rock 'n' roll my guitar.
What I did:
It was smooth sailing until the last part. First I installed the shielding, along with the grounding ring in the cavity + the 400 DC .33 uF cap and checked that everything worked before removing the old parts.
Humbucker's change went without a hitch. Potted all my pups at this point.
All the new parts checked out and were within 1% of their specified specs. Put 'em in. Left the new switch out and did a trial with the stock wiring. No problems.
Swapped the new switch in and carried out the wiring. No sound comes out and the multimeter is indicating a short between hot & negative at the output jack.
I'm certain I have no dud components or cold solder joints, but I can't spot where I messed up the wiring. I suspect three locations for the issue:
- I had to mickey mouse the initial schematic as I have one tone pot. I found a thread by another gentleman who had a similar issue and used that as my basis. My electrical diagram is below.
- Tone pot has been wired incorrectly.
- Volume pot has been wired incorrectly.
For reference here's the original:
In my guitar the B- going to ground includes the conductors for south coil start and bare shielding. The north coil and south coil finish are spliced together as in a standard two-conductor. North coil start is B+ in the circuit.
Any thoughts on what I did wrong? Any improvements are also welcome.
Some pictures of the spaghetti bowl.
Thanks in advance,
Cesar
What I did:
Thanks in advance,
Cesar
