Post by ashcatlt on Sept 12, 2012 14:14:58 GMT -5
Uggg, was going to post a link, but it's in the Members Only area of diystompboxes.com. So, dude has taken these things which look like resistors, but are apparently chokes, stuck some magnets under them, and got it to make sound. I just ran across it here at work, so cant check the sound samples. Though y'all might find it interesting. Pic:
Sound samples which I haven't yet heard: on a strat on a "mandolele" on an acoustic(Links Borked!)Edit: Well, looks like neither the pic nor the li ks actually work! Cant figure that out. I even quoted the message from over there and copied the whole img tag over here and it wont show up. Maybe click here?
Post by asmith on Sept 17, 2012 3:04:10 GMT -5
Interesting concept. Your last image works but I can't get to any of the sound samples.
The inductors are 0.1 millihenries (mH), +/-10%.
Post by reTrEaD on Sept 17, 2012 11:40:34 GMT -5
This seems quite odd. One would suppose the magnet buttons are polarized in the vertical axis and the inductors are oriented in the horizontal axis. Dunno what to think about that.
Post by sumgai on Sept 17, 2012 15:55:15 GMT -5
ash, It's very unusual for you to post links that don't work. Worse, even the Mighty Google says that FileDropper has no clue about chokes, mandolele's or anything else you've mentioned. Houston, we've got a problem here. sumgai
Post by ashcatlt on Sept 17, 2012 18:52:58 GMT -5
Those sound sample links worked when I posted them, but seem to have failed since. Is FileDropper one of those temporary hosting things? I cannot figure out why the pic won't display. It seems to work fine in the OP over at the other forum. asmith, you're a member over there so you could check out that post. I encourage the rest of you to join. diystompboxes is pretty cool! A lot of knowledgeable folks, and mostly pretty decent and friendly and helpful. 4real is a member over there, under his alter-ego "psw", and posted in the thread I pulled this from:
