Post by angelodp on Dec 1, 2012 1:10:33 GMT -5
Correction DC59 Dano Guys, forgive me if I am on a tear. I gave up the series parallel idea for the SG because the pups had single conductors and no separate case ground. This DC30 does have that. I looked at JohnH's 2nd module for the S/P implementation but its not working for me. I am sure I have some error here, but I cannot figure it. I used a DPDT one side as I did not have the SPDT that Newey Suggested. guitarnuts2.proboards.com/index.cgi?board=schem&action=display&thread=4571Simply put I want to use the gib switch and simply add one switch to the setup so I can have the two pups in either series or parallel.
Post by newey on Dec 1, 2012 9:40:23 GMT -5
ange- JohnH's idea switches the "ground" (what Dano calls "neutral") wire of the neck pup onto the "hot" of the bridge to make the series connection. With the switch set to "series", you get series with the 3-wayswitch flipped to the bridge neck setting, and bridge pup only in the other two settings. I took the liberty of modifying your diagram. I used one-half of a DPDT, as you indicated. I think this has got it, but let's let John look at it first.
Post by angelodp on Dec 1, 2012 10:26:44 GMT -5
Thanks Newey. I have another idea here as well based on info I found. Also uses DPDT.
Post by JohnH on Dec 1, 2012 14:52:39 GMT -5
Neweys version looks good to me. I assume red to ground and black to hot is OK? no reason why not except red is a hotter colour.
One small point of correction, to use that set up in series, you flick the toggle to the neck position, and the other two settings will give bridge.
Thats how I have my LP, thinking that having series and bridge would be the most useful two choices once the series switch is set (which is on the rear of the guitar in my case, so not accessible mid-song). But having had it now for a couple of yaers, I think I might chnage it to hav the neck as the single option - since I'm more likely to use neck as a rythym setting, then series for lead. I mention that in case youd like to think about a similar choice in your case.
The other version of this switching that I use in some designs, is to fully overide the toggle in series mode. This may be better if the S/P switch is accessible, so you set whatever normal setting you like on the toggle, then operate the S/P switch and it always goes to series. This would use the other half of the switch, and the diagram could be adapted.
Ang - how is your latest drawing intended to operate? I havent cjecked it.
Post by angelodp on Dec 1, 2012 15:56:26 GMT -5
Hi, gonna try Newey's version. Mine is culled from internet, not sure how it would work?
Ok Newey, JohnH.... as always you guys rock. It works great. The series has great balls and growl in OD and the Jimmy Page sounds are still lurking for the normal operation.
Thanks guys
A
Post by newey on Dec 1, 2012 18:58:14 GMT -5
Ange- Glad you got it working and like it. The second diagram you posted, the one "from the internet" will also work. In that diagram, as JohnH mentioned, the series setting overrides the 3-way toggle. You're in series regardless of where the three-way is set. Just "completing the thought" here for the next guy who comes along wanting this.
Post by angelodp on Dec 2, 2012 13:59:16 GMT -5
One small note. Neweys version ( what I did ) will produce the series pickups when the gibson switch is in the Bridge position. Then the Gibson switch will go to neck in the other two positions. Here is my final graphic. I realized its DC59 ( not DC30 ). Cheers
