Post by cynical1 on May 8, 2013 16:30:47 GMT -5
Well, after dumping the ex-wife, losing the farm...and much other unrelated procrastination...I have finally finished Project #2, aka Blue Murder.
Here she is:
Obligatory Headstock Decal Shot.
The original plate from the GTX33 body.
The finish is just an indigo automotive lacquer with multiple clearcoats, then wet sanded and buffed out to give it the shine you see above. The neck is clear poly on the headstock, satin on the back of the neck and matte on the fingerboard. The neck was also sanded and buffed out.
HISTORY:
The body is an old GTX-33 basswood body I scored on eBay for $25.00. I never took any pictures of the actual body, but this is what it looked like when it showed up:
Pretty fugly, ain't it... I don't know what type of paint they used, but it was like sandblasting cast iron to get it off.
It was originally routed for a Floyd Rose...but since I'm not much of a fan of either Mr. Floyd or Mr. Rose I decided to make it a hard tail. I routed out the body in a similar fashion to what I did on Project #1. I didn't have any alder left, so I just cheaped it out and used red oak. It was tougher to sand and re-route for the slanted pickup routings, but it was all I had laying around. Again, I didn't take any pictures of the actual work, but thanks to Google I found some sample shots to illustrate how the body was rerouted, filled and re-routed for the single coils:
TOP:
Both of these large routings were filled with a 1" piece of white oak. The straight routings for the single coils were cut at an angle that escapes me at the moments, but it matched what I found in an old Fender blueprint, then reversed to put the high end closer to the neck.
BACK:
This was routed down about 3/16" and filled with a 1/4" piece of white oak. This leaves a small chamber in the back where the springs used to live.
It was designed for a 24.75" scale and and the Tele neck is set for a 25.5" scale. I toyed with the idea of moving the bridge pickup routing down, but the more I looked at it the more I wanted to see how it'd sound with the bridge pickup so far up from the bridge. I've never been a great fan of the bridge pickup tone "so shrill it makes dolphins cry" anyway. This meant the neck and middle pickup would be squeezed, but the angled routings helped with the pole alignments. This is a very ballsy full sounding guitar. Using only one pickup is sort of like keeping the Ferrari in second gear...you really lose its main design advantage in doing so.
The neck was a $35.00 partially CNC'd one piece maple neck I scored on eBay. I left it thick like a baseball bat as I intended on using the heaviest flatwound strings I could find on it. It's strung with a 13-56 ga. set from Webstrings. The fingerboard markers were in, but there were no side markers. I couldn't find my bag full of marker stock, so I went out to the barn and cut some 10 ga. solid copper wire pieces, drilled the side and used them as side markers. They have the unique property of looking dark when in ambient lighting, but they also shine when a light is aimed at them, making them quite effective in low light conditions.
[/td]
[/tr]
[/table]
The frets are profile 6105, leveled, crowned then buffed with a little rubbing compound on a Dremel polishing wheel. The nut is a standard Tusq Fender style.
The tuners are a set of Wilkinson vintage tuners. The neck was predrilled for a vintage set and the Wilkinsons are nice tuners for the money...especially on eBay, and the extra weight helps balance out the guitar. I think they look better on a Tele headstock than the sealed tuners anyway.
The bridge is a Schaller 475, pretty much my "goto" hardtail bridge. It's gold because that's what came up on eBay that day. Plus, it came out of New York City, which seemed to go with that whole Blue Murder theme...
Even though this is a basswood body, by the time you add up the oak filler pieces, all of the electronics, the Schaller bridge, the thick neck and the vintage tuners I tossed on to counterbalance the body, it weighs in at a respectable 7-3/4 pounds. (3.4kg) Slightly more than a JEM, about equal to an alder Strat...but still several pounds less than a Les Paul.
You can read all about the trials and tribulations of working out the switching on this beast here at OK, somebody look over my shoulder here......only for those with a strong constitution...
Here's the details on the pickups:
For reference, here's the wiring diagram:
So, what's it sound like, you may ask... Well, JohnH calculated that this guitar has a potential of 544 tonal options. I'm still playing with the original 40...
This is what they look like:
This is what they do:
Point and Click tone Options:
1) Neck *
2) Neck & Middle +
3) Neck & Middle *
4) Middle *
5) Middle & BridgeN +
6) Middle & BridgeN *
7) Middle & Bridge Humbucker + (Humbucker in local +)
8) Middle & Bridge-Humbucker+ (Humbucker in local *)
9) Middle & Bridge-Humbucker* (Humbucker in local +)
10) Middle & Bridge-Humbucker* (Humbucker in local *)
11) Middle & BridgeS +
12) Middle & BridgeS *
13) BridgeN *
14) Bridge Humbucker + (Local)
15) Bridge Humbucker * (Local)
16) BridgeS*
17) Neck & Bridge-N +
18) Neck & Bridge-N*
19) Neck & Bridge-Humbucker+ (Humbucker in local +)
20) Neck & Bridge-Humbucker+ (Humbucker in local *)
21) Neck & Bridge-Humbucker* (Humbucker in local +)
22) Neck & Bridge-Humbucker* (Humbucker in local *)
23) Neck & Bridge-S+
24) Neck & Bridge-S*
25) Neck, Middle + & Bridge-N +
26) Neck, Middle * & Bridge-N+
27) Neck, Middle + & Bridge-N *
28) Neck, Middle * & Bridge-N*
29) Neck, Middle + & Bridge Humbucker+ (Humbucker in local +)
30) Neck, Middle +& Bridge Humbucker + (Humbucker in local *)
31) Neck, Middle +& Bridge Humbucker * (Humbucker in local +)
32) Neck, Middle +& Bridge Humbucker * (Humbucker in local *)
33) Neck, Middle * & Bridge Humbucker+ (Humbucker in local +)
34) Neck, Middle *& Bridge Humbucker + (Humbucker in local *)
35) Neck, Middle *& Bridge Humbucker * (Humbucker in local +)
36) Neck, Middle *& Bridge Humbucker * (Humbucker in local *)
37) Neck, Middle + & Bridge-S +
38) Neck, Middle + & Bridge-S*
39) Neck, Middle * & Bridge-S +
40) Neck, Middle * & Bridge-S*
Sound samples are in the works. I'm working on putting it together in the same format that JFP uses combining sound clips with a video so you can actually follow what the switching is doing. This may take a while...
If you made it this far, I applaud your determination. Hope is was worth the 20 minutes you invested.
Finally, I want to give thanks and credit to where it's due. This guitar was in the back of my mind for years, but without the patient assistance of ChrisK, JohnH and Asmith I never would have been able to pull this off. I 'm sure Chrisk was looking over my shoulder while I was doing this one...smiling to himself and thinking, "wait 'til he finds out he wired that switch backwards..."
Happy Trails -
Cynical One
EDIT: Edited picture of controls to make it clear exactly what the Hell they are.
Here she is:
HISTORY:
TOP:
BACK:
No direct light | Slight direct light | Direct light |
[/tr]
[/table]
SCREW | POLE | COIL (S) | SLUG | COIL | POLE(N) | |
Winding/Polarity | Start | Finish | Polarity | Start | Finish | Polarity |
Seymour Duncan SSL-1 | N/A | [N/A | N/A | White | Black - | North |
Rio Grande Halfbreed RW/RP | N/A | [N/A | N/A | Gray | Black - | South |
DiMarzio DP197 Virtual PAF (Bridge) | Green - | White + | South | Red + | Black - | North |
1) Neck *
2) Neck & Middle +
3) Neck & Middle *
4) Middle *
13) BridgeN *
16) BridgeS*
Happy Trails -
Cynical One
