abcdefg
Post by abcdefg on Jul 10, 2013 16:42:27 GMT -5
CAN SOMEONE PLEASE POINT ME TO OR SEND ME A SIMPLE TO UNDERSTAND WIRING DIAGRAM FOR THE ABOVE SUBJECT SET-UP ??......PRETTY SIMPLE, JUST NEED TO SPLIT THE COILS ON THE HUMBUCKER IN THE BRIDGE WITH THE MINI TOGGLE .....THE 3-WAY SWITCH IS TELE TYPE ......THANKS EVERYONE !!
Post by newey on Jul 10, 2013 18:49:14 GMT -5
abcdefg- Hello and Welcome to G-Nutz2! First of all, no need to shout (IOW, turn your caps lock off. ). Yes, it is pretty simple. In fact, you don't even need a complete wiring diagram, since 90% of the wiring is exactly the same as a stock Tele. So, what I'll do is get you a module to split the HB This module will then simply be "inserted" into the stock Tele diagram, and you then have everything you need. No need to put me, or anyone else, through the redundant task of re-drawing the stock Tele wiring part. The coil split module gets inserted "first in line" after the bridge HB and before the switch. As I'll show you on the diagram. But first, a few questions: Are the pickups both the same brand? What brand(s) are they? What are the wire colors for the pickups? Does the HB have at least 3 wires, not counting any bare or braided wires? Have you already purchased a mini-toggle switch, and if so, what type is it? Are the pickups currently mounted in the guitar? Are they currently wired in? The answers to these questions will help me make a diagram of the coil split module with the correct wire colors and wired so as to make the middle switch position (that is, the "both pickups" selection) hum-cancelling when the bridge HB is split.
