Post by Deleted on Jan 17, 2014 2:13:37 GMT -5
Hello nutz, i am thinking of redoing the Aria strat once more, in the path of leading it to perfection! Its about position 3. As of late, i dont hate the middle pickup alone (DMZ FT1) as many other guitarists do. But i'd also like to try the neck/bridge combination. This guitar in its final form (minus the middle which i wanna discuss here) will have the following configuration : - bridge connected to middle tone pot (with the original GN extra capacitor trick) - bridge DMZ FT2, wired for in series/parallel via the middle/bridge push/pull tone pot - neck DMZ The Chopper, wired for in series/parallel via the volume push/pull tone pot Now the question is about the middle. I thought of this wiring for the neck tone push/pull which will control the middle position: This push/pull is intended to be pulled up, only in the 3rd position. There it makes sense. In other positions, it would always connected in parallel bridge and neck, which would be kind of redundant, besides 2-4 where it would connect all pups in parallel. So, do you see any gotchas besides this?
Post by JohnH on Jan 17, 2014 3:11:11 GMT -5
I hope you like N+B. It seems like you'll get it in all 5 positions.
Post by Deleted on Jan 17, 2014 3:37:15 GMT -5
Thanx John!
