LJA1st
You never know what around the next corner unless you walk with a mirror on a stick
Post by LJA1st on Feb 27, 2014 12:08:59 GMT -5
Hi people I'm brand new to this board . This is the guitar in question Im fiercely Scottish and also an ancient old fart who play's blues and rock mostly and Ive decided to rewire my beast . My question is The circuit says North start , North finish . I presume this means the Start wire is the Plus wire . I'm wiring up two humbuckers to a two vol one tone with series/split/parallel switch for each pickup and a master series/parallel and and a phase for the neck and bridge . The Guitar is a left handed solid body LP style which I made meself .The pickups are Warmans , 12 gauge at the neck and a Destroyer at the Bridge . . OK So thats the question . Is the Start wire the plus wire ?
Post by reTrEaD on Feb 27, 2014 13:30:34 GMT -5
Hi people I'm brand new to this board . Welcome aboard. Glad you chose to join us! Is the Start wire the plus wire ? The answer to that question is the same as the answer to: "What should I wear to my urologist appointment for my bladder control problem?" Depends. In the case of a pickup, it depends on which direction the coil is wound and which magnetic polarity. Most HB pickups have both coils wound clockwise. The screw coil has magnetic polarity of 'south up'; the slug coil is 'North up". (Up = closest to strings) So ... The 'start' wire of the slug (north) coil of a HB is most likely the 'plus wire' and the 'finish' wire of the screw (south) coil of a HB is most likely the 'plus wire'. But ... Neither of your pickups have the usual slug and screw coils. However, Warman does have some information on the wiring of their pickups. 12-Gauge: www.warmanguitars.co.uk/downloads/Warman-12-Gauge.pdfDominator: www.warmanguitars.co.uk/downloads/Warman-Dominator.pdf
LJA1st
Post by LJA1st on Feb 27, 2014 14:56:37 GMT -5
Right thanks for that .Warman have assured me the Destroyer is the same wiring as the 12 gauge So I'm going to presume the start is the positive and go from there . Cheers
Post by reTrEaD on Feb 27, 2014 16:35:03 GMT -5
Your presumption is likely to result in your wiring for the north coils being correct and your wiring for the south coils being backward.
LJA1st
Post by LJA1st on Mar 5, 2014 7:36:29 GMT -5
Done it and Im pretty happy with the sound .Took me a while as the eyesight isnt as good as it was but got there without too much mess .
