Post by merseymale on Jan 28, 2016 22:41:28 GMT -5
HI! wanna try a new variation on a twin HumBucker Tele with single volume & tone but cant find a wiring diagram. I imagine I'll need a super switch: www.premierguitar.com/articles/Exploring_Fenders_5_Way_Super_SwitchI'm hoping for Position ONE/back: Bridge HumBucker* Position TWO: Bridge Single Coil(ie spilit HB) Position THREE: Both HumBucker** Position 4:Bridge Single Coil(ie spilitHB)& Neck HumBucker* Position FIVE: Neck Single Coil(ie spilitHB) *1 pup in Series just like, say, a Les Paul, etc... **2 pups in parallel just like, say, a Les Paul or Tele etc... Thanks in advance!
Post by newey on Jan 28, 2016 23:48:17 GMT -5
Something like this will do the trick- and, yes, you'll need a Superswitch. Note that I have omitted the Vol and Tone controls, and jack. These are wired as per standard practice. Also note that Seymour Duncan colors are used. Your colors may vary. Also note that a Tele control cavity is a bit tight for a regular Superswitch, and the cavity sidewall may need to be modified for one to fit. However, there is a "thin Superswitch" now available that slides right into a Tele, no woodworking needed. These are not universally available, however. The "Thin Superswitch" is not to be confused with the "Half Superswitch", which is a 2-pole version (that you don't want.)
Post by merseymale on Apr 11, 2017 7:16:31 GMT -5
Something like this will do the trick- and, yes, you'll need a Superswitch. Note that I have omitted the Vol and Tone controls, and jack. These are wired as per standard practice. Also note that Seymour Duncan colors are used. Your colors may vary. Also note that a Tele control cavity is a bit tight for a regular Superswitch, and the cavity sidewall may need to be modified for one to fit. However, there is a "thin Superswitch" now available that slides right into a Tele, no woodworking needed. These are not universally available, however. The "Thin Superswitch" is not to be confused with the "Half Superswitch", which is a 2-pole version (that you don't want.) VERY belated thanks, newey but much appreciated
