www.seymourduncan.com/pickup/seth-lover-setThese humbuckers are not wax potted. As far as I can tell, it's essentially what you get if you were to buy an uncovered humbucker and then solder an aftermarket cover on top of it. As seen in pictures below, the pickup is extremely clean as a result, and features a maple spacer. The wire used for the coils has a dark red color.
My ultimate goal is to compares a few popular, mass produced "PAF" clones, and so far it's just this and the
DiMarzio 36th Anniversary , and I can tell you now that the Seth Lover set is decidedly brighter and lower output than the 36th Anniversary set. The loaded peaks are about 300Hz higher across the board, and the inductance is 300mH lower in the neck, and 800mH lower in the bridge. There might also be physical aspects to the tonal product due to the lack of wax potting in the Seths.
Seymour Duncan Seth Lover SH55BSeries resistance: 8.00k ohms
Series inductance: 4.835H
Gauss: 280 slug, screw 310G, AlNiCo 2 bar
Unloaded: V: 19.4dBV f: 6.07kHz (black)
Loaded (200k & 470pF): V: 17.6dBV f: 2.50kHz (red)
Seymour Duncan Seth Lover SH55NSeries resistance: 7.39k ohms
Series inductance: 4.158H
Gauss: 270 slug, screw 320G, AlNiCo 2 bar
Unloaded: V: 19.2dBV f: 6.29kHz (black)
Loaded (200k & 470pF): V: 17.7dBV f: 2.80kHz (red)
Baseline V: 16.7dB
Bode PlotThese plots are with the cover on:
Since the plots above are with the cover on, I measure the pickup with the cover on and off in order to see the extent of difference that it makes:
Unloaded, the cover causes a -3.2dBV drop at the resonance, and with a typical "real world" load, the drop is only 1dBV, right on the threshold of being audible. These results are
near identical to those seen with the DiMarzio 36th Anniversary , suggesting that the covers are more or less the same.
Screw and Pole Piece ComparisonI transplanted the screws and pole from a Gibson '57 and put them into the Seth Lover SH55B in order to see if the swapping of those steel core materials show any difference:
There is no difference. To date, I have never noted an difference between steel poles or screws that were similar in dimension, but I measure them anyway since there is a lot of talk out there about grades of steel and the difference they supposedly make. It looks like the Gibson's screws might be a hair less conductive than the Seth's, but it's all academic, as the difference is totally inaudible.
PicturesCovers removed... JACKPOT! a double cream Seymour Duncan! The neck is zebra, however.
No wax. Not a drop.
Info on how these tests are conducted
guitarnuts2.proboards.com/thread/7723/measuring-electrical-properties-guitar-pickups
