syddd
Post by syddd on Oct 17, 2016 6:21:42 GMT -5
Post by ChristoMephisto on Oct 17, 2016 16:31:16 GMT -5
Could try used ones instead. There's two on fleabay made from Grayhill, and a bit cheaper too.
What are you using them for? Do they fit in a solid body guitar, or for thick hollow bodies?
syddd
Post by syddd on Oct 18, 2016 3:58:54 GMT -5
Could try used ones instead. There's two on fleabay made from Grayhill, and a bit cheaper too. What are you using them for? Do they fit in a solid body guitar, or for thick hollow bodies? I've seen them there, but I'd rather avoid buying a switch with bits of solder still hanging off the lugs if possible. I was looking at these switches in particular as they would fit in a Stratocaster body - any of the other heavy duty stuff I've found wouldn't fit in the cavity. I'm looking to use one in combination with a 5-way superswitch so I get 15 unique pickup combinations in a stealth strat without having to use push-pulls.
Post by reTrEaD on Oct 18, 2016 6:43:59 GMT -5
