Post by ChristoMephisto on Oct 17, 2016 16:56:50 GMT -5
Recently modified my tele again with a Broadcaster style blend. Where it blends the neck with 100% bridge through a single 250KA pot. Using a reverse pot seems more intuitive and works better when rolling up the pot. Worked out rather well, and sounds better then straight parallel. This got me thinking about the parallel half out of phase position. Since the neck being hoop'd causes a reduction in output, the bridge pup could be blended as well to either balance or vary it. Looked around and the closest is a strat with a n/b blend and the neck having a phase switch, but no comments on the sound or results. Has anyone tried something similar to this and could comment? Read somewhere a change in volume effects the phase cancellation, or is this not the case since there is only resistance of the blend pot between the bridge and the neck's hoop cap?
