stonabus
Post by stonabus on Dec 27, 2005 16:22:30 GMT -5
is he using a push pull pot there? also, on the switch and the vol(?) pot, do the "a" and "b" wires connect to eachother? i think i can do this mod, but im new at wiring schematic reading. sorry for the bother, if this is common sense to most of you. im building a strat with lipstick tubes in it and i want to use this mod. from what i can tell, i need a five way four pole switch and a push pull pot. does it make a difference if i use a push push? also, do i have to put a phase switch in there? thanks in advance.....
