twangdang
Post by twangdang on Nov 22, 2017 22:01:03 GMT -5
Looking for the following combinations on a 2 humbucker guitar with a 5 way switch 1.Bridge HB 2.Inside coils of each HB in series 3.Neck HB + Bridge HB in parallel 4.Outside coils of each HB in series 5.Neck HB Need all positions hum cancelling.I'm thinking I'll have to flip a magnet and use a super switch type 5way for starters. Can anyone get me started?
Post by newey on Nov 23, 2017 1:19:33 GMT -5
twangdang-
Hello and Welcome to G-Nutz2!
It's easier to rotate one of the HBs 180°. Assuming both HBs are of the same manufacture, you will want one screw coil and one slug coil for the inners, which will then give you one apiece on the outers as well. If the pickups aren't the same, you'll need to test for N and S to be sure you get hum-cancelling.
Undoubtedly. It may be a day or two before I can do a diagram, but at first blush I think this can be done with a superswitch.
Post by Yogi B on Nov 23, 2017 18:21:49 GMT -5
Can anyone get me started? This diagram from Phostenix is close, the main difference being that the 2 and 4 positions are exchanged. Plus it would also need modifications to reflect the physical/magnetic orientation of your pickups. HHSeriesSplit.jpg (287.44 KB)
