gbagbauv94
Post by gbagbauv94 on Dec 19, 2017 19:24:49 GMT -5
Hi, maybe you’ll all have an answer to my question: My guitar have a configuration of two single coil (Lace Sensor Hot Gold) and a Humbucker(Seymour Duncan SH-11 4 conductor wiring) My wiring is working but my Hum is way too loud compare to the two other Lace’s, i drop my pick up almost in the guitar wile the others are to close of the strings... How can i fix this issue??
Post by reTrEaD on Dec 19, 2017 20:58:20 GMT -5
Hello G and welcome to GuitarNutz2.
You might have other problems like a wiring error but extreme distance from the strings to the pickup is usually a bad plan. It results in lower output from the string signal and a need to turn the volume up. Does your SD keep up with your Lace singles when it's so far away from the strings, or does it sound weak when you select it and not change the amp settings or volume control on the guitar?
gbagbauv94
Post by gbagbauv94 on Dec 20, 2017 6:27:50 GMT -5
Actually yes, the SD have a lack of sound definition, my guitar is a Godin Session with push pull split humbucker, i’ve tried a lot of wiring possibilities and i dont know the proper wiring to fix my problem
Post by reTrEaD on Dec 20, 2017 11:23:43 GMT -5
Could you post a diagram of the wiring you're currently using?
