bodsterbug
Post by bodsterbug on Mar 5, 2018 16:08:00 GMT -5
Hi! I'm working on a custom Tele build with 2 humbuckers and a 5 way Megaswitch for different options. I have a wiring diagram as follows: 1. Neck Humbucker in Series 2. Neck humbucker in Parallel 3. Both in Series 4. Bridge humbucker in Parallel 5. Bridge humbucker in Series Link Here: guitarelectronics.com/2-humbuckers-5-way-lever-switch-1-volume-04/Position 3, I would probably never use. Is there a way that position 3 could be both pickups out of phase? Searched all over but can't find a diagram and my head is hurting trying to work it out lol. Cheers! Justin
Post by thetragichero on Mar 5, 2018 16:28:25 GMT -5
two series humbuckers out of phase with each other? take one of the pickups and wire all of the pickup wires (not including the bare shield wire) backwards should work? so for example, the bridge pickup wire north start to ground, north finish to where the bridge south finish is, south finish to where north finish is, south start to where north start is? since that's the only setting where the two pickups are both on together, that should work... but please allow someone(s) to verify for me before bringing out the gun
Post by thetragichero on Mar 8, 2018 15:18:31 GMT -5
sometimes a picture is worth 150 words...
