Post by studiostriver on Jun 13, 2020 8:32:36 GMT -5
I don't have any tools or skills to make a better drawing. Normally my drawings are ok for others to follow but it is quite a complex scheme. Are there parts that are not clear? things to note: All wires connect to switch or pot lugs. Where one wire crosses another wire in the diagram, they are not connected For the two push-push pot/switches, the cases of the switch are grounded. The diagram shows a thick black wire connected to the top of the switch bodies, where usually there is a lug to solder to Instead of resoldering it all again, those tests, even just the first one, might quickly identify the issue with no work Update news. My luthier spent half day with his electrician friend and they said with tough work they made it all work as intended. All position are functional and he add a that guitar sounds really good with these Ionzier pickups,and that all changes are noticeable with changing electronics on/off/on and push push combiantions. I expecting guitar to be shipped to my place in a few days. Lets hope everything work and sounds as good as he said.
Post by JohnH on Jun 13, 2020 16:03:00 GMT -5
That's great news, looking forward to hearing about what you think of it!
Post by studiostriver on Oct 8, 2020 21:12:29 GMT -5
The story went terribly complicated. I had to buy original JP7 nut cause luthier damaged it while he wanted due to bigger ss frets to move it tiny bit higher. I had to order nut from USA, to return it back to luthier. It was the most stressful project I ever had in my life, thanks God its over. This is the picture from luthier after final polishing, tomorrow he sending it to my home.
Post by studiostriver on Oct 10, 2020 10:30:09 GMT -5
Post by studiostriver on Nov 8, 2020 20:01:22 GMT -5
Sound demos coming in 2/3 days when I find time from work. Pickup scheme works just great.
Post by unreg on Nov 10, 2020 17:42:09 GMT -5
SS, wow... 24 frets AND 7 strings... that neck looks thick; your hands must be large. So happy for you; can’t wait to hear it!
