Post by antigua on Mar 7, 2020 15:35:45 GMT -5
I bought the Strat set www.strat-talk.com/threads/mojotone-quiet-coils-for-strat-analysis-review.534842/ and they looked like pretty good pickups, though I'm still waiting on others parts in order to put them into a Strat. I bought a set for the Tele, and have installed them, and they sound pretty good to me.
The design is basically a "single coil sized humbucker" that uses two AlNiCo "blades" instead of two steel "blades" as is typical of Bardens, DiMarios and all the rest. The only other production pickup that comes close to this are Gibson Firebird pickups, which are not single coil sized. Then there is a fake vintage looing facade over the top that makes the single coils sized humbucker look like a vintage single coil. The neck pickup just uses a conventional looking cover, but the bridge pickup has a really convincing top, with a real, and very thin piece of fiber board, and shiny looking fake pole pieces that. They have sort of a plasticy sheen to them that is not identical to AlNiCo, but it's good enough, IMO, even better than the Strat version. These Tele pickups seem to be all around more refined that their Strat version, they feel more solid and look more perfected.
$180 isn't a bad price for such a novel pickup set. I'm impressed by the apparent effort that went into the design, especially considering how the vast majority of the models that come out these days are nothing less than lazy tweaks and reissues of existing production pickups.
MojoTone claims their QuietCoils match the electrical values of actual vintage pickups, and testing them shows that to be true. There isn't a single spec that couldn't be matched to a vintage Telecaster single coil.
Since AlNiCo blades are used in the construction, and because AlNiCo is more resistive, there are low eddy currents, and so the Q factor is rather high, like vintage pickups. Thusly, these pickups will pair well with stock 250k tone and volume pots and don't require 500k pots, as MojoTone had suggested in a FAQ. This is in contrast to steel blade pickups, such as those offered by Seymour Duncan, which due to the steel parts, pair better with 500k pots. Ironically, even though Seymour Duncan's steel blade pickups pair would better with 500k pots, they claim their Strat sized humbuckers suited for 250k value pots.
I had a Tele ready to take these pickups, so I installed them and have used them, and they sound good similar enough to vintage style single coils to me. I was a little worried they might be under-powered due to the unique AlNiCo blade configuration, but the output seems fine. I did set the pickups closer to the strings, knowing the Gauss strength of the blades is only around 500G, similar to AlNiCo 3, and about half that of AlNiCo 5 pole pieces.
Mojotone Quiet Coils for Telecaster
Bridge
- DC Resistance: 7.446K ohms
- Measured L: 3.105H
- Calculated C: 126.24pF
- Gauss: 570G (AlNiCo 5)
Neck
- DC Resistance: 7.887K ohms
- Measured L: 2.396H
- Calculated C: 162.11pF
- Gauss: 400G (AlNiCo 5)
Bridge unloaded: dV: 9.3dB f: 7.63kHz (black)
Bridge loaded (200k & 470pF): dV: 5.0dB f: 3.47kHz (blue)
Neck unloaded: dV: 6.5dB f: 7.46kHz (red)
Neck loaded (200k & 470pF): dV: 4.4dB f: 3.76kHz (green)
Bridge
Neck
