yahont
Post by yahont on Jun 26, 2020 12:47:09 GMT -5
Greetings! I asked a question here on the H-H-H scheme of the respected John Hewitt (Three humbuckers 3x5). I had a crazy idea to add a piezo to this scheme. To the 2 potentiometers available in the circuit, another device is added - a blender such as this - www.noll-electronic.de/guitar-electronics/mixpot/ The problem is that this blender works like a buffer, that is, it raises the mid and high frequencies. I want to add another 3-position toggle switch to the circuit, for example, which needs to make a bypass of magnetic pickups and a bypass of a piezo (left position — bypass signal from magnetic pickups, middle position — no bypass ( magnetic and piezo work through a blender), right position — bypass piezo) . Is it possible to do this with a toggle switch? What toggle switch should be? if it’s real, I ask you to help with the scheme (drawing), if it’s not real, I ask you to suggest how this problem can be solved. Thank you all in advance! I undertake then to show the finished result on the forum.
yahont
Post by yahont on Jul 1, 2020 15:05:59 GMT -5
