Post by newey on Aug 17, 2020 12:00:01 GMT -5
Where is the input?
Post by frets on Aug 17, 2020 12:34:12 GMT -5
Hi Newey,
The red wire runs to the input to the volume or directly to the jack. It’s just an output. See what I mean?
Post by newey on Aug 18, 2020 5:46:24 GMT -5
The red wire runs to the input to the volume or directly to the jack. It’s just an output. See what I mean? No, sorry, I don't. The red wire is the signal output, as designated. Where does the signal from the pickups (or other switching) come into the circuit?
Post by frets on Aug 18, 2020 6:58:32 GMT -5
Hey Newey, The pickups go on the switch. Switch to Volume, I’ll draw it out and post it. This tone pot to the Volume Input (or straight to the Jack).
Post by sumgai on Aug 18, 2020 8:43:34 GMT -5
Hey Newey, The pickups go on the switch. Switch to Volume, I’ll draw it out and post it. This tone pot to the Volume Input (or straight to the Jack). frets , you're getting too terse, and confusing our poor Counselor. You should've noted that the pickups go to the selector switch, else-wise it looks like you meant the p/p on the pot.
newey, This is a replacement for a standard Tone control - swap one for the other, at will. But I do shudder to think what it will sound like in an "after Vol pot" configuration. Ugh. HTH sumgai
Post by reTrEaD on Aug 18, 2020 9:28:54 GMT -5
The red wire is the signal output, as designated. Where does the signal from the pickups (or other switching) come into the circuit? newey, think of this as a shunt device, much like a typical treble-cut tone control. The input is the output.
Post by newey on Aug 18, 2020 9:34:54 GMT -5
Got it, my mistake. "Output" threw me off.
Post by frets on Aug 18, 2020 10:37:58 GMT -5
