slej,
It's all in how you look at it.
Let me be the first to say, Kinmans are the primo pickups on this planet. They cost more than almost anyone else's product, but they do sound so much more desirable than anything else. As the friend who introduced me to them said: "once you try these things, you'll throw rocks at everything else!"
For the record, I don't add anything to the volume pot, I think that what I get out of a bit of roll-off sounds just fine. You might say that, to to my ears, it already sounds 'correct'. But I do understand that others don't feel the same way, they want something different. Well, lucky for them, we have options.
First, your analysis of a series R/C (resistor and capacitor) combo is fairly correct, you do limit how much signal gets into that cap. But the problem with that is, the resistor stays the same value. As you crank the pot downwards, the
ratio between the resistor and the pot's upper section changes. In turn, this changes the total amount of signal being byhpassed by the capacitor. How much? Enough for you to hear it, for sure. Effecitvely, the further you turn down, the greater the
percentage of total signal will flow through the pot's upper segment. Less signal flow through the capacitor means less effect, which in turn should translate to "less tinny" as you roll-off the control.
What about a parallel R/C combo? Glad you asked. Here, we're directly changing the shape of the pot's taper, or response curve, if you prefer. Consider, for a moment, the resistor in parallel with the pot's two "upper" terminals, no capacitor at all.
What you now see is the pot's upper segment of the total resistance being bypassed by the resistor to the wiper, give us a 'resistors in parallel' situation. As you might recall, the formula for that scenario is R1 x R2 divided by R1 + R2. If we do some example calculations, we'll get an idea of what that external resistor is doing to the response curve. For our purposes, the resistor is 100Kohms, and the pot is 500Kohms, with a linear taper.
Pot turned fully up:
(wiper shorts to terminal, resistor is fully bypassed)
Pot turned fully down:
(wiper shorts to ground, signal is null and void)
Pot turned 10% down:
10% of 500K = 50K
50K x 100K = 5,000K
50K + 100K = 150K
5,000K / 150K = 33.33K
Hmmm, interesting. Instead of there being 50K ohms present in the upper leg, we now observe only 33K ohms. So what's this do to the bypass capacitor? Well, without going into a bunch of wizardly exotic formulas, it should be easy to see that once again, more signal is flowing through that 33K resistance than would flow through a 50K resistance, right? And for the purposes of the capacitor, which is in parallel with the 33K, it will get less signal to work on (at it's appropriate frequencies). Once again, we see that the effect of the bypass capacitor has been reduced a bit, theoretically giving us a less tinny sound as the pot is turned downwards.
The net effect is almost the same for either a series or parallel scenario, given a judicious choice of resistor and cap values. While we could derive "magic" cap and resistor values scientifically, I find that no part of me wants to think like a scientist while I'm playing! It falls to the individual to choose what sounds best to him/her by trial and error. The values you see listed in circuits like these are merely good starting points, that's all. Your amp/speakers, your cables, the newness of your strings, all of these things and so many more will influence the effect of this mod.
My advice? If you didn't like the cap by itself, then go for the series R/C combo first. Try a few cap and resistor values, and see what plucks your string.
Don't like it? Try a parallel setup.
"But wait", you exclaim, "that's a lot of work". Nonsense, watch this: Leave all the controls in your ax turned up. Cut off the bad end of a 'broken' cable, then strip back the insulation from the wires
on the good end. Plug that gizmo into your guitar's output jack, and now you've got we we tecnical types call a 'test jig'. You can use alligator clips to hook up pots, resistors, capacitors, whatever you want. Just "wire" them up in a temporary fashion, and run another cable to your amp. If you're carefull (don't rock the house down!), you'll be able to use this test bed for finding that exact combo that stiffens your pencil.
When you're done, put the appropriate components in your rig, and
then rock the house down!!
