Post by newey on Nov 10, 2020 16:08:33 GMT -5
frets- Nice idea, but you may want to correc the caption, i.e., "4DPT"??. Also, with the transformer, are you just using the primary? Is 1.5H the inductance of only the primary side or the total?
Post by frets on Nov 11, 2020 12:26:32 GMT -5
Thanks Newey, I appreciate you catching my typo. It really is a great little system. As you know, Tele’s are so limited control-wise and tone-wise and this setup allows considerable diversity. Enough of that !! Ha!! The Audio Signal Transformer is your typical Xicon, where only the primary is used with the center tap lead cut; as well as, the secondary leads. This results in an induction right at 1.5H. This would be the Xicon 42TL022. I am fearful that the 42TL022 may have been discontinued. I’ve been trying to find more but can’t seem to find them, even on Mouser. I do use other transformers in my harnesses. Typically, with those, you must cut the center tap, connect one side of the primary and secondary leads, and run the hot and ground in a horizontal manner. What I need to do is do a little diagram of audio signal transformers so everyone can see how to connect these little buggers. I love the the ability to select different capacitor values; as well as, inducting them. I know it’s kinda a theme of mine. Anyway, I will fix the typo. Thanks again for checking it.
