Post by ourclarioncall on Dec 9, 2020 9:23:19 GMT -5
On European import amps I see they have a red selector thingy at the back to select your countries voltage
If for example I bought a fender amp from Italy or Germany or some other country that has different voltage and different plugs, how would I change that for U.K. use? Is as simple as turning the red selector to 230v and then taking off their plug from the cable and wiring up a British plug ?
Post by Jaga on Dec 28, 2020 18:10:20 GMT -5
AFAIK the UK voltage is the same as the German one – 230V. In this case if you'd like to use European amp in the UK, you'd need only to plug it somehow. You could either resolder the plug or use adaptor like this.
