Post by ziggystardust723 on Feb 3, 2021 22:10:55 GMT -5
Hello Strato Addicts, If nobody before tell this job: - a good way for getting your Middle pu RW/RP on a Strato, without to get an other pu: -1) 1st: you have to Buy 2 Magnets for Changing the magnetic Side of your Middle Pickup: the Strongest, = 2 'Neodymium' magnets (conceived for Trains in Japan..), really much Strong (my 1st 2 where on a table, around 40 cms from each other, but came in exploding themselves by contacting.. I'd to comand 2 0thers) - & not Expensive: around 10/12€ for2 - you have to comand Rectangular Magnets (as bigger than a Strato pu), > & Not Round.. - After, when you get your magnets, & after changing the Polarity, > You've just to Change the Wires Electrically: - when you're in front of your pu: - at your Left is the Black Wire (which goes actually to - ..) > You change it, & make it going Now to the + => to the Selector.. - & for the 0ther Wire: on your Right (White or Yellow, linked to + ..) > you Change & make it going to - (it's like this one than Strato pus had to be wired/linked in 1st: = Beginning of the Coil going to +, & the End at the - .. > much less Buzz than the + 0utside) > A simply mode & also to Keep your Middle pickup: always better than to change it for 0ne than you know nothing, & maybe different.. - I know this & other things on pus, as I wind pickups since 8 years.. (I'm actually 66yo, & play R&R!.) - Bye, Ziggy (France, 4h10)
