Post by pablogilberto on Mar 8, 2021 8:22:24 GMT -5
Hi guys!
I've seen Ibanez doing some Power Tap in order to get a higher single coil output whenever a humbucker goes into a coil split.
It says that it's not really a full coil split. The other coil is full, the other one is low output.
I have some questions:
#1 Would you know the actual circuit for this?
#2 Is this technique same with the Fralin Partial tap?
#3 During the power tap, since both coils are active (although one is low output), will they have hum-cancelling? I think they will have but not as effective compared to a full humbucker. Is this correct?
