Post by frets on Aug 11, 2021 11:27:44 GMT -5
How do I find this stuff?
Post by unreg on Aug 11, 2021 15:06:19 GMT -5
Does Fleor make quality potentiometers? Since you have shared this Iβm going to guess they have claimed the quality. Have you actually used/worked with one or many? π€π And what impression have they made?
Post by unreg on Aug 11, 2021 16:39:46 GMT -5
Wow, only ~$2.97 each?
Post by frets on Aug 11, 2021 18:06:00 GMT -5
Hi UnregπΊ,
I have no idea how these pots would rate and would buy some but my snobby clientele want only CTS or Bourns (which is not their fault, most have never heard of Fleor).
However, I have bought other Fleor parts and felt the quality was pretty good; e.g., Pickguards and a set of Alnico HSS. The look almost exactly like CTS 450GTβs. My guess is that they are an improvement over Chinese pots (excluding Taiwan) and probably would work just fine. But again, thatβs just speculation.
Post by unreg on Aug 12, 2021 10:34:29 GMT -5
Post by ssstonelover on Aug 12, 2021 13:54:15 GMT -5
I have installed a set of Fleor pickups (rail type) and the construction and fit was quite good. In terms of sound the customer was well satisfied; their kind of sound. I have also bought some push-push pots from Fleor and they too look very well made and have nice brass parts. Unfortunately I have not yet installed them so can't give a track record about performance/reliability over time, but I do really like the idea they are push-push and not push-pull, a big advantage with Strat type knobs which are hard to pull up.
Post by frets on Aug 12, 2021 13:58:15 GMT -5
Oh, I do remember that I have tried the Fleor Push-Push pots. I had a customer that wanted push-push. They worked just fine, quality was as good as an Alpha Taiwan push pull.
I think Iβll but a set of the Fleor pots and report back.
Post by gumbo on Aug 13, 2021 3:46:16 GMT -5
Look forward to your report on that Frets, I want to swap out the push-pull pot on the Burns... Many thanks..
Post by thetragichero on Aug 27, 2021 16:48:14 GMT -5
I have installed a set of Fleor pickups (rail type) and the construction and fit was quite good. In terms of sound the customer was well satisfied; their kind of sound. I have also bought some push-push pots from Fleor and they too look very well made and have nice brass parts. Unfortunately I have not yet installed them so can't give a track record about performance/reliability over time, but I do really like the idea they are push-push and not push-pull, a big advantage with Strat type knobs which are hard to pull up. those appear to be either made by bourns or bourns knock offs. no opinions either way they just look familiar
