Post by JohnH on Oct 25, 2021 7:22:35 GMT -5
ok, ill do a diagram for that soon.
Tinus
Post by Tinus on Oct 25, 2021 7:26:00 GMT -5
Awesome, thank you! Looking forward to seeing it!
Post by JohnH on Jul 3, 2022 3:51:18 GMT -5
9 months later, here it is... It's based on the version using your current pickups, ie the bridge does not do series/parallel etc. But I showed the spare push pull, and we can adapt the design to suit this later, Here are the settings Basic: B blends to B+N B+M blends to B+N+M M M+N N Pull the series switch: B blends to B + (NxM in series) B+M M M NxM series
Tinus
Post by Tinus on Jul 4, 2022 6:10:00 GMT -5
Wow, amazing John! This will take me some time to decipher haha!
If you don’t mind me asking for your help a little bit more: what are those two yellow parts in the schematic?
Also, for this schematic I will need to buy the following parts: - 3x 500K audio potmeter with standard length bushing, of which 2 are Push/Pull (https://www.tonefactory.nl/alpha-push-pull-500k-audio-potmeter-standard-length-bushing-375-3-8-diameter-made-in-taiwan) - 2x 470k resistors (https://www.vanallesenmeer.nl/Weerstand-470K-Ohm-1/4w-5?gclid=Cj0KCQjwnoqLBhD4ARIsAL5JedI_JWLmqhH3FAgnWJwBUkmkV1B0VsKhdZbv1gB6f9eWAV0PNrgcjswaAsCiEALw_wcB) Is this correct?
Post by JohnH on Jul 4, 2022 8:14:22 GMT -5
All good. The pots and 470k resistors seem fine. The yellow parts are capacitors. It doesn't matter what style you get but I drew them to look like yellow poly caps that are quite common. The larger one is the main tone cap 22nF (equals 0.022uF) and the smaller one is 1nF =1000pF, in parallel with 150k. These are the treble bleed.
Tinus
Post by Tinus on Jul 6, 2022 6:39:41 GMT -5
All good. The pots and 470k resistors seem fine. The yellow parts are capacitors. It doesn't matter what style you get but I drew them to look like yellow poly caps that are quite common. The larger one is the main tone cap 22nF (equals 0.022uF) and the smaller one is 1nF =1000pF, in parallel with 150k. These are the treble bleed. So I’ll also need to get: - 1x 22nF capacitor (https://www.vanallesenmeer.nl/22NF-0.022UF-100V-5-POLYESTER-FILM-BOX-TYPE-CAPACITOR-WIMA-MKS2) - 1x 1nF capacitor (https://www.vanallesenmeer.nl/1NF-0.001UF-100V-5-POLYESTER-FILM-BOX-TYPE-CAPACITOR-WIMA-FKS2) - 1x 150k resistor (https://www.vanallesenmeer.nl/Weerstand-150K-Ohm-1/4w-5) Is that correct?
Post by JohnH on Jul 6, 2022 7:14:34 GMT -5
Hi Tinus, yes that's all fine
Tinus
Post by Tinus on Jul 6, 2022 7:19:34 GMT -5
Thanks for checking! I’ll order all these parts and start working on the guitar soon! 😄
Post by JohnH on Jul 6, 2022 8:47:06 GMT -5
Great! Will you start with your current pickups as we discussed before? or do you have the new ones now? It won't take as long to add the option for the bridge coil cut or series-parallel!
Tinus
Post by Tinus on Jul 7, 2022 14:00:34 GMT -5
Still have my old one. I want to first try out this new wiring. Probably I will like it enough to not swap the humbucker out
Tinus
Post by Tinus on Aug 31, 2022 9:47:13 GMT -5
Hi! I'm on and off working on this schematic. I came across two questions: What am I supposed to do at the first tone pot where the top two "ports" are seemingly linked together? Do I have to solder them together with a small cable? And what do the dark gray squares mean on the pots? Do I have to do anything to them? Thanks in advance!
Post by newey on Aug 31, 2022 11:55:46 GMT -5
What am I supposed to do at the first tone pot where the top two "ports" are seemingly linked together? Those are the solder lugs, not "ports". The short black line between the 2 lugs means you wire a short "jumper" between the two. That jumper is making the series connection when the push/pull is pulled up. JohnH included a push/pull on the blend pot for future wiring of series/parallel for the bridge pickup. There's nothign wired to it at the moment, so nothing you need to do. It look like John simply "cut and pasted" that push/pull from the other one, and the black squares got copied over in the process. Looks like he was using the black squares simply to indicate that something was connected to those lugs, but there are a couple where he omitted the blackening. So don't read anything into those, just wire according to the diagram.
Post by JohnH on Sept 2, 2022 2:27:59 GMT -5
Yes I left the spare switch on the pot for the future parallel-series switching, if you want to try that with a different 4-wire humbucker.
The dark squares on the switches aren't very significant, but they indicate the common pole connections on the switches which connect to the outer lugs.
The short wire between switch lugs is just a cnnecton link, a piece of wire soldered between lugs. You can use a piece of bare wire, or extend the stripped end of a connected insulated wire to bridge across.
Tinus
Post by Tinus on Sept 2, 2022 2:39:13 GMT -5
The short wire between switch lugs is just a cnnecton link, a piece of wire soldered between lugs. You can use a piece of bare wire, or extend the stripped end of a connected insulated wire to bridge across. Thanks guys for your clear explanation! So could I use the wire that’s coming from the volume pot to also function as the connection link if I strip it off enough to also touch that switch lug?
Post by JohnH on Sept 2, 2022 5:16:09 GMT -5
Yes indeed! That's what I'd do.
Tinus
Post by Tinus on Nov 9, 2022 6:39:37 GMT -5
I finally got around finishing this wiring scheme! I'm really excited to string the guitar up and test all the new sounds! But before I do that I want to make sure I got everything wired up correctly. I made a video to show it:
Tinus
Post by Tinus on Nov 11, 2022 5:27:21 GMT -5
I strung the guitar up because I was so excited to try it out, but I think I must've done something wrong in the wiring. All of the positions where the middle pickup is combined with another pickup (N+M, NxM, M+B, MxB) sound awfully thin and very low in output, even the series settings. I made a sound demo to show you guys what it sounds like. Hopefully someone knows where I went wrong and how to fix it! Sound demo
In the demo I play through all the positions, in order: Neck > N+M > Middle > M+B > Bridge > NxM > Middle > MxB > Bridge > N+B > N+M+B
Post by newey on Nov 11, 2022 9:54:36 GMT -5
Tinus- My first thought was that the middle pickup was out of phase, which would mean just swapping the + and - wires around to fix it. But then I listened to your demo recxording and now I'm not sure. Typically, with an out-of-phase setting there is a pretty noticeable drop in output, particularly for the parallel settings, but your levels seem consistent throughout the recording. You can check the phasing of the middle pickup without dismembering the guitar by using the "screwdriver pull-off test"
Tinus
Post by Tinus on Nov 12, 2022 6:29:05 GMT -5
The weird thing is that this ocurrs only when the middle pickup is combined with another pickup. The middle pickup by itself sounds fine! Hopefully someone knows what I did wrong..!
Post by newey on Nov 12, 2022 6:35:08 GMT -5
The weird thing is that this ocurrs only when the middle pickup is combined with another pickup. That's what makes me think it's out of phase with the other two pickups. It may be that I'm just not hearing it so much in your samples. Check the phase first.
Tinus
Post by Tinus on Nov 13, 2022 10:02:43 GMT -5
I think I don't really understand how this test works. What am I supposed to see on the meter when I touch the pickup poles?
If it ends up being out of phase, then I just have to solder the black wire where the white one is and vice versa, correct?
Post by newey on Nov 13, 2022 12:23:31 GMT -5
If it ends up being out of phase, then I just have to solder the black wire where the white one is and vice versa, correct? Yes, assuming those are the middle pickup wires. As JohnH describes in that post, if using a soundcard/PC to do the test, you'll be looking for one "spike" to be downward (presumably on the middle pickup) while the other 2 are upwards, or vice versa. If you're using an analog multimeter, look for the needle to swing opposite on the middle pickup. There was discussion of testing with a digital meter but I've never been able to see the difference with a digital meter. If you have a digital meter, I suggest using the PC way JohnH describes as it is more definitive. To be in phase, all three pickups should go either "up" or "down" on either the meter or PC graph.
Tinus
Post by Tinus on Nov 26, 2022 4:10:01 GMT -5
I managed to fix the issue! It really was as simple as switching the two wires of the middle pickup around. Now the guitar sounds amazing and I’m really happy with it! The singlecoils really sound like singlecoils, while the bridge humbucker still has it’s power. The neck + middle series combo works fine, but it doesn’t quite have that power that the real humbucker has (obviously). I don’t know if there maybe is a wiring trick that I could do to give it a little extra push. The blend knob is also an interesting feature. It’s nice that it adds a little bit of warmth to the bridge or middle & bridge settings, but it also feels like it loses a bit of it’s bite while doing that. I think time will tell in which way I will end up using these extra options. Overall I’m really happy with how this project turned out. I managed to properly wire everything up by myself, and now all of my pickups sound pretty great + I have a lot of extra options to experiment with! I want to thank everyone who replied on this thread and in particular ofcourse John for putting so much time and work in creating this awesome diagram and continuously replying to my many questions. I am very grateful for that!
