Post by pablogilberto on Oct 15, 2021 7:37:56 GMT -5
Hello!
Does anyone know what type of epoxy resin are used for pickups like EMG81 and Musicman Bass pickups?
I'd like to try a repair but I'm not sure about the epoxy potting part.
Not sure which solution and curing method are safe/recommended.
Will appreciate if you share info or product links.
Thank you!
Post by thetragichero on Oct 15, 2021 12:58:02 GMT -5
disclaimer: i am neither a pickup manufacturer nor pickup expert. just a schlub willing to try to fix things himself
that being said, i'm sure just about any two part epoxy would work. the difficult part is keeping it where you want it and away from where you don't
Post by ms on Oct 18, 2021 7:19:49 GMT -5
Hello! Does anyone know what type of epoxy resin are used for pickups like EMG81 and Musicman Bass pickups? I'd like to try a repair but I'm not sure about the epoxy potting part. Not sure which solution and curing method are safe/recommended. Will appreciate if you share info or product links. Thank you! There can be thermal issues with some epoxies. Any number of places carry stuff for potting, even Walmart on line! (https://www.walmart.com/c/kp/potting-epoxy, after the first one on the list).
