SPRING
Oct 19, 2021 3:21:32 GMT -5
Post by Deleted on Oct 19, 2021 3:21:32 GMT -5
Not my normal area
But i wonder if there was any other springs you can uses for the tremolo so have a softer spring near the bass end of the strings just wondering what the differences would make as tend to pull from one corner
SPRING
Oct 19, 2021 3:43:03 GMT -5
Post by Jaga on Oct 19, 2021 3:43:03 GMT -5
I believe (not sure) that on some tremolo systems which have multiple springs, their tension can be adjusted. Need to experiment and let us know!
SPRING
Oct 19, 2021 9:25:57 GMT -5
Post by thetragichero on Oct 19, 2021 9:25:57 GMT -5
tension can be adjusted based on how many springs you place and how you place them (also by how far you screw the claw into the cavity). you generally want more tension on the bass side of the block than the treble side because those strings are going to pull more
SPRING
Nov 6, 2021 5:00:17 GMT -5
Post by Deleted on Nov 6, 2021 5:00:17 GMT -5
I guess making the spring shorter (dam i dont want to cut one and remoled it) would make it a bit more toughter i guess
I did think would need less more bass because the Arm is at the bottom (far away from the Bass straings) in relation Guess this is a more of a problem on a floating bridge than a screwed in one
SPRING
Nov 6, 2021 10:14:07 GMT -5
Post by thetragichero on Nov 6, 2021 10:14:07 GMT -5
your springs don't particularly care about the arm because that's not the pivot point. the pivot point is either the 6 screws (vintage strat style vibrato) or the two posts. the springs are to counteract the pull from the strings
SPRING
Nov 6, 2021 12:55:40 GMT -5
Post by Deleted on Nov 6, 2021 12:55:40 GMT -5
im not sure on that.. going to think a bit ..
Three Types .. the Cheap Screwed in one, Floating Post one .. and the Flydd Rose (because it goes forward and backwards) We are tilting at the force of the springs so for the floating/Screwed down one, i would have to use the force of the total of the springs pulling but we dont need to go all the way to ZERO force on the trem.
SPRING
Nov 28, 2021 13:45:46 GMT -5
Post by psiloguitarensis on Nov 28, 2021 13:45:46 GMT -5
yo be honest i have tried light springs and currently run 4 black springs. sustain increased with more tension. tone became more clear i guess you could say. whammy bar has more control and less sensitive which im heavy handed. currently have ernie ball 11's wanna try ernie ball baritone 13's might even try High E 13 B 18 G 30 D 44 A 56 Low E 72
before you say wow those are big strings well im heavy handed and have big fingers like stevie ray though hands and wrist are to stout to be that fast or awesome.
Post by pyrroz on Dec 10, 2021 5:56:31 GMT -5
why? IMHO tension is mostly uniform distributed across strings. Also likeliness of bends are the same across bass, middle, treble strings.
