Post by frets on Oct 19, 2021 15:56:34 GMT -5
Hi Guys, Im thinking about making another type of concentric tone pot. Maybe a concentric Bass cut/treble cut with a little different setup. I ran across this tone concept from Joe Gore, the Tonefiend guy. I just wanted some thoughts on it before I spend my time building it. It looks like a variation on the Greasebucket but not quite. Do you think I could use the concept on both pots of a concentric that would produce a sort of nice roll in bass cut and treble cut?
Post by ashcatlt on Oct 19, 2021 18:04:44 GMT -5
I mean the small cap is just across the output (or I guess pickup? depends how the V pot is wired) always and could be placed in several other places to accomplish exactly the same thing. Then this is just any old T control. I’m not super clear on how you intend to implement this as bass cut, so it’s tough to say how that might work out.
Post by frets on Oct 19, 2021 19:24:09 GMT -5
Ash, I really don’t know yet. It looks like if I place the small cap where it is, it will bleed into the other pot whatever is on it? Or will it? I have to sit down and diagram it out. My goal would be to get a more gradual cut on each pot by using the “small cap.” I’ll have both outputs coming off of each pot so I now don’t foresee any bleeding over. I want to treat both pots independently and achieve that more gradual cut. More of a range of cuts . But that’s just me thinking. I have to draw it out. I don’t want a situation where one pot is just additive to the other darkening the tone.
Post by thetragichero on Oct 19, 2021 19:33:38 GMT -5
this appears electronically identical (if not schematically, but electrons don't care how you draw `em) to the small cap that was in parallel with the pickup on my 65 guild freshman. i could NEVER get enough treble out of it but once i removed the cap (and embiggened one of the pots for extra measure) there is now plenty of treble to cut bass (in the simplest RC filter sense) you need a series cap with a resistor to ground. maybe i have explained poorly but this should help visualize it: www.muzique.com/schem/filter.htm
Post by ashcatlt on Oct 20, 2021 15:41:28 GMT -5
Yeah like I said the small cap literally just kills treble any time that thing is connect. It’s not helping anything be “more gradual”. It’s just making it darker overall.
Post by frets on Oct 20, 2021 16:39:34 GMT -5
Alpha makes two dual gang pots that fit a Tele cavity. Here they are: The second pot to the right is marketed by a lot of other companies, but it is an Alpha because I buy these from an Alpha Distributor. I have often used the concentric to do a volume and tone, including tone caps on both sides, Greasebuckets, Rothstein’s, tying the tone pot to a 4PDT mini Varitone (I’ve shown that one on the forum). I use them a lot on bass harnesses with the Volume and the tone carrying two caps on lugs 1 and 3 (usually .047 and .068). I would like to be able to put together a high pass/low pass configuration that would work like a PTB but have increased connectivity methods and a more gradual roll in of tone. That’s where using Gore’s tone pot came up in my mind. But I see no way to make a more versatile bass and treble pot beyond the G&L PTB that Retread, Sumgai and SSStonelover helped me convert to a concentric pot.
Post by ms on Oct 22, 2021 10:37:08 GMT -5
As ashcatit said the small cap is just across the pickup when the tone control is connected, and therefore its function is to lower the resonance frequency a bit. Why would you want to do that? If it was too high, you would expect the pickup maker to wind on more turns, lowering it and increasing the output. I think the real question is why anyone uses the big cap. It has no function until the pot gets most of the way to zero and then it produces a very low resonance frequency. This makes the guitar sound sort of like a bass, and maybe in the very early days it replaced the instrument that Leo had not yet invented.
The big cap can be replaced with a resistor (10K, 20K, whatever). From 10 on down the circuit first behaves in the normal way, reducing the Q of the resonance, but then it transitions to an almost a pure LR filter. IMO, useful for setting overdrive tone.
Post by Deleted on Nov 6, 2021 5:39:15 GMT -5
To me it reminds me of some forms of G&L circuits ive seen with a 1nF going to ground before the Tone Circuit Cable to Pot, Lug 3, Lug 2 and the "Small Capacitor" are all ont the same line
