Post by frets on Nov 8, 2021 12:33:12 GMT -5
Revised Reversed switch Tele w/Coil Split
Post by Deleted on Nov 8, 2021 15:40:48 GMT -5
I dont know enough about a 4 way switch but i would need 3 poles if i was going to do Series as i would have to control the TWO outputs and the End of one of the pickups
the way around it is to Tie one Output and one to Ground like you did on one of your circuits
if it is a simple 2P4T +Neck = Output +Bridge = A0.. A1=OUTPUT, A2=OUTPUT, A3=-NECK, A4=ground -Neck = B0.. B1=output, B2=GROUND, B3=+BRIDGE, B4=GROUND -Bridge = Ground
Bridge, Bridge + Neck, Neck x Bridge, Neck
Then you also have your Full Humbucker / Bridge North
