coloxim
Post by coloxim on Dec 24, 2021 17:11:46 GMT -5
Hi, I understood how work switch 5 way, but i don' t find any scheme about the fender switch SWITCH 5-WAY LEVER 4 pole DISCRETE
someone could help me, please?
thank you so much!
Post by sumgai on Dec 24, 2021 17:38:36 GMT -5
coloxim, Hi, and welcome to the NutzHouse. What you're describing is what the guitar world calls a Superswitch - 5 positions, 4 distinct poles, each with discrete tabs or lugs for connections. I think that if you use the Search box from the menu above, you'll find that just entering "Superswitch" (all one word, no space), you'll get a ton of posts to look at. But perhaps we can shorten that search - what do you have in mind for using that switch? HTH sumgai
coloxim
Post by coloxim on Dec 24, 2021 18:30:44 GMT -5
Hi,
thank you so much!
is it like a superswitch? because i saw the superswitch but they haven't 4 pole, but 6... i'm a littel bit confuse...this one have 4 and 6 pole...the 4 pole are connected to the 6?
anyway in hss stratocaster i want to turn on neck pickup with s-1, and have autosplit in 2 position(or 4th)...
coloxim
Post by coloxim on Dec 24, 2021 18:54:14 GMT -5
i've also another question... is better to use one volume pot with 250k and 500k in the same pot or use a 500k pot with 2 parallel resistor for the single coil?
Post by sumgai on Dec 24, 2021 23:16:55 GMT -5
..... is it like a superswitch? because i saw the superswitch but they haven't 4 pole, but 6... i'm a littel bit confuse...this one have 4 and 6 pole...the 4 pole are connected to the 6? No, there are only 4 poles on a Superswitch. I think you may be confusing a terminal (where you solder a wire) with the word "pole". In a 5 discrete position switch, there are 6 terminals, 1 of them being common to the other 5. Those other terminals are selected individually when the actuator is moved to a new position. Now, I've just described a single pole on a Superswitch. Multiply that by 4, and you have the entire switch. And don't forget, there is a "half-Superswitch" that has only 2 poles. Sometimes this is a good thing for simple jobs, and it doesn't cost as much as the full Superswitch. anyway in hss stratocaster i want to turn on neck pickup with s-1, and have autosplit in 2 position(or 4th)... This can be done, but it seems like overkill if that's all you want to do, because the combination of a Fender S1 and a Superswitch can accomplish a heck of a lot more. What other pickup combinations might you want to achieve? i've also another question... is better to use one volume pot with 250k and 500k in the same pot or use a 500k pot with 2 parallel resistor for the single coil? This is a common question here in The NutzHouse. I personally like to use 500K or 1Meg pots for single coils, because I can always turn down the Tone pot a little bit, or I can just not turn up the Treble control on the amplifer quite so high. But many others do prefer a 250K pot, there's nothing wrong with that. However, using a pair of resistors to jump across the terminals of a 500K pot to reduce it to 250K will "work", but it changes the way the volume is reduced - instead of a smooth decline, the rotation might cause a small change in one area, and an unexpectedly large change in another area. Some of that depends on the resistor values, and it should be obvious that what sounds good to the user will most likely require some experimentation. HTH sumgai
MattB
Post by MattB on Dec 25, 2021 7:05:13 GMT -5
The Fender Discrete 4 pole switch isn't the same as other superswitches. It has one superswitch wafer, which has two poles with a separate lug for each position, and one standard 5-way wafer, which has two poles with the usual three lugs for five positions.
Fender do also sell a "standard" superswitch, which works the way sumgai described. The part number for the Discrete version is 0078776049. The part number for the normal, non-shorting version is 0992251000.
coloxim
Post by coloxim on Dec 25, 2021 9:05:59 GMT -5
..... is it like a superswitch? because i saw the superswitch but they haven't 4 pole, but 6... i'm a littel bit confuse...this one have 4 and 6 pole...the 4 pole are connected to the 6? No, there are only 4 poles on a Superswitch. I think you may be confusing a terminal (where you solder a wire) with the word "pole". In a 5 discrete position switch, there are 6 terminals, 1 of them being common to the other 5. Those other terminals are selected individually when the actuator is moved to a new position. Now, I've just described a single pole on a Superswitch. Multiply that by 4, and you have the entire switch. And don't forget, there is a "half-Superswitch" that has only 2 poles. Sometimes this is a good thing for simple jobs, and it doesn't cost as much as the full Superswitch. anyway in hss stratocaster i want to turn on neck pickup with s-1, and have autosplit in 2 position(or 4th)... This can be done, but it seems like overkill if that's all you want to do, because the combination of a Fender S1 and a Superswitch can accomplish a heck of a lot more. What other pickup combinations might you want to achieve? i've also another question... is better to use one volume pot with 250k and 500k in the same pot or use a 500k pot with 2 parallel resistor for the single coil? This is a common question here in The NutzHouse. I personally like to use 500K or 1Meg pots for single coils, because I can always turn down the Tone pot a little bit, or I can just not turn up the Treble control on the amplifer quite so high. But many others do prefer a 250K pot, there's nothing wrong with that. However, using a pair of resistors to jump across the terminals of a 500K pot to reduce it to 250K will "work", but it changes the way the volume is reduced - instead of a smooth decline, the rotation might cause a small change in one area, and an unexpectedly large change in another area. Some of that depends on the resistor values, and it should be obvious that what sounds good to the user will most likely require some experimentation. HTH sumgai Ok, thanks for the explanation... What can I do more? With super switch I've always 5 position, I've to renounce to one position to do something different? So is better have a pot volume with 250 and 500k...
coloxim
Post by coloxim on Dec 25, 2021 9:06:55 GMT -5
Yes, I've 4pole discrete, but there is a scheme of it? I don't find anything...
angellahash
format tables
Post by angellahash on Dec 25, 2021 10:11:35 GMT -5
Them switch do you really need a diagram.
You should be able to see what is happening it's all open!!
A common goes on all the pole track The track has a smaller connections that touch a track that is hooked on the main track You can see how it works it's all visible
Post by sumgai on Dec 25, 2021 12:30:02 GMT -5
It has one superswitch wafer, which has two poles with a separate lug for each position, and one standard 5-way wafer, which has two poles with the usual three lugs for five positions. That was interesting, to say the least. I was unaware of that bastardized version, and for the life of me, I can't fathom any reason to make such a thing, not even a minute reduction in the cost to manufacture it. But hey, I'm a Luddite of the first stripe, so who am I to cast aspersions here?  sumgai
angellahash
format tables
Post by angellahash on Dec 25, 2021 14:41:15 GMT -5
I've always wanted to change the track that all these lugs travel over.
I think some damaged ones and I want to look at the track that it rotate on. But how to make a copy out of metal. Would need stamp maybe !
coloxim
Post by coloxim on Dec 26, 2021 17:47:12 GMT -5
thanks guys!!
Post by newey on Dec 26, 2021 18:05:05 GMT -5
So, like sumgai, I had never seen or heard of this switch before, and it does seem kind of silly. You wouldn't be able to do anything with it that couldn't be done with a regular Superswitch, but it is much more limited than the Superswitch, so unless there is a significant cost difference, I can't see much use for this.
Basically, what I would envision for this thing is that you would wire the one half of the switch that is a regular Strat 2P3T to give the standard Strat parallel combos. You would then need a second switch, a mini toggle or push/pull pot (could use an S-1 but would be overkill, you don't need the S-1's 4 poles), to switch from the regular 5-way side to the "half superswitch" side to give you other options. The second half is like a "half Superswitch", a 2P5T switch, so switching to that mode could allow for some series combinations, N + B, and so forth.
Post by newey on Dec 26, 2021 18:43:05 GMT -5
Here's a couple of Fender factory wiring diagrams using this switch, just for purposes of illustration. Bottom line, Fender doesn't seem to be doing much with this switch.  This is a diagram for a 2014 HSS "American Standard Shawbucker Strat". One pole of the regular 5-way deck of the switch controls the neck and middle pickups, while the 2 "Superswitch" poles controls the bridge HB and routes all 3 pickups to output. The switch options are just regular 5-way switching, the only real reason for the "discete switch" is to allow the use of a dual-gang volume pot to separate the V and T controls for the bridge HB. Not clear to me why they thought they needed this particular switch to do that . . .  This is for a 2013 HSH American Deluxe Strat. Here the Half-Superswitch deck of the discrete switch is used to split the neck HB in position 4 and to split the bridge HB at position 2; the regular 5-way half of the switch is wired just like any Strat, so it gives the coil splits pluds the middle pickup at 2 and 4. They are only using one pole of the Superswitch half; again, seems the could have done this with a regular 5-way switch.
Post by reTrEaD on Dec 27, 2021 11:12:56 GMT -5
You wouldn't be able to do anything with it that couldn't be done with a regular Superswitch, but it is much more limited than the Superswitch I disagree with the first part but somewhat agree with the second part. For instance: To accomplish the typical N|N+M|M|M+B|B selection with a superswitch, you need two sections of the superswitch, leaving you two sections of the superswitch for other tasks. You can accomplish the typical N|N+M|M|M+B|B selection with just one section of standard part of the switch. That leaves two sections of the superswitch for other tasks AND the other section of the standard switch for other tasks. So I reckon if you look long and hard enough, you just might be able to find something you can do with the DiscReet switch that can't be done with a superswitch.
otoh ... You aren't limited to the typical pickup selections and the accompanied sequence when using a superswitch. So there's inherently more flexibility there. ime, there are a LOT of things you can do with a superswitch that you can't do with this switch. And there are a rare few things you might do with this switch that can't be done with a superswitch. YMMV.
MattB
Post by MattB on Jan 6, 2022 6:02:08 GMT -5
There are a few Fender designs that get a little more use out of the switch. The American Deluxe and American Elite both use a 4-pole discrete switch and an S1 switch to add five extra selections. I think from Fender's point of view an big advantage of this switch is probabaly that it's easy to keep the standard dual tone control setup. Personally I'm not a fan of having both tones active in position two, and I don't see any benefit that would be worth using a different switch, but I could see Fender not wanting to release a Strat that didn't have exactly the standard selection of sounds.
