talon119
Post by talon119 on Jan 22, 2022 12:21:20 GMT -5
I am in the weeds with this one need a diagram for 3 humbuckers all coil split 1 push pull volume and 1 push pull tone and a 5 way switch any help would be awesome thankyou in advance.
Post by newey on Jan 22, 2022 13:11:15 GMT -5
talon119- Hello and Welcome to G-Nutz2!I am in the weeds with this one need a diagram for 3 humbuckers all coil split 1 push pull volume and 1 push pull tone and a 5 way switch Let's try to "zero in" a bit on exactly what you want. First off, is this a standard Strat-type 5-way switch? What pickup selections do you envision on the 5-way? Are we using the 5-way for some of the coil splitting, or are the coil splits going to be on one (or both) of the Push/Pulls? One push/pull can split all 3 humbuckers, but you may not be able to maximize hum-cancellation in single-coil mode by doing so. Using both P/Ps to split the coils (2 HBs on one P/P, the third HB on the other would allow for some HB/SC combos; if you put all three coil splits on one switch, then you're either split or not split on all 3 HBs simultaneously.
