thez
Post by thez on Mar 17, 2022 12:21:36 GMT -5
Hi guys, I'm gonna wire-up my HSS tele with a Schaller Megaswitch M and a push-pull pot The pickups are: Bridge: DiMarzio Chopper (mini humbucker) Middle: DiMarzio Cruiser (it's actually an humbucker that sounds like a single coil) Neck: DiMarzio Twang King (real single coil) What I want to achieve is this: position 1a: bridge full humbuckerpos.1b (pushpull): bridge split coil position 2: Neck & Middle in series position 3: Neck & Middle in series Out of phase position 4: Neck & Middle in parallel position 5: Neck The Schaller Megaswitch M has 4 indipendent stages so I drew a schematic. Could you guys be that gentle to have a look at it and tell me if it's correct? I would appreciate it. Thanks
Post by newey on Mar 17, 2022 12:43:50 GMT -5
thez-
Hello and Welcome to G-Nutz2!
We'll need a second opinion before you start wiring this. But your diagram looks fine to me. With the push/pull, you'll be splitting the bridge HB to the coil with the red/black wires, so make sure that's the one you want to be active. If you want the other coil instead, it's an easy change.
Post by Deleted on Mar 17, 2022 15:54:11 GMT -5
Does as you want so can't fault it. Did love the trick with position 4 using the he ground from N to share with M
thez
Post by thez on Mar 18, 2022 5:54:40 GMT -5
Thank you guys!
