Post by timtam on Apr 29, 2022 7:47:29 GMT -5
I was recently reading Wacker's 2019 article on 'outlaw' pickup parameters (his term) in Premier Guitar - inductance, resonant peak frequency, and Q factor. Some good stuff, but not all of it is the most straightforward piece of writing for that audience, especially regarding Q. And although he mentions the importance of measurement conditions, he doesn't define the loading conditions under which the parameter values/ranges he quotes were measured.
www.premierguitar.com/mod-garage-exploring-outlaw-pickup-parameters
But it did make me think ... what are "typical" low/medium/high ranges of values for the bode plot's parameters, and other parameters, recorded under standard conditions ? For the bode plot, those conditions would be the commonly-used/agreed, realistic loading of 470 pF/200 kOhm. Having the low/medium/high ranges would help in placing any new pickup under consideration in the context of its peers. And also add to the existing understanding of how particular physical features position their pickups within the range of measured values.
I couldn't think of a resource I'd seen that already describes those ranges (if there is one, what is it ?). I was going to ask the question here as to what people judged the ranges to be, but then I realized I could compute ranges myself from available data, that is, antigua's comprehensive pickup test database at:
www.echoesofmars.com/pickup_data/viewer/
I focussed on the data for resonant frequency (at 470 pF/200 kOhm loading), inductance (at 120 Hz), capacitance (at 100 kHz), and DCR; there is more data there, but no Q data.
antigua's database currently contains data for about 80 HBs, 180 strat pickups, and 80 tele pickups. There are not enough P90s, jaguar, or jazzmaster pickup types there to calculate meaningful ranges. I did not attempt to divide tele pickups into bridge and neck (I may do that later); nor was there any distinction made for any nominal placement description within the other 2 pickup categories. I also did not check the database for any "unusual" pickup designs within a pickup category that might have atypical data values. Instead, possible "outlier" values that might distort the true picture for the range of "most" data were dealt with via quartiles/'box and whisker' plots, discussed below; all 4 data types had some outliers. So please excuse any apparent statistical complexity - that was necessary to understand the distribution of values. I will try to explain it clearly for anyone interested in the minutiae. If you're not interested in that detail, just look at the values for each range - "low", "medium", and "high".
I decided on the following quartile-based definitions for "low", "medium" and "high" ranges for each of the 4 parameters. All ranges were calculated using inbuilt Excel functions.
Specifically ...
LOW range - the lower ~25% of the individual data values. From the lowest NON-outlier value to the 1st quartile value.
MEDIUM range - the middle 50% of the values. From the 1st quartile value to the 3rd quartile value ('inter-quartile range', IQR).
HIGH range: the upper ~25% of the data values. From the 3rd quartile value to the highest NON-outlier value.
Average - the median value (more robust that the mean value in the face of outliers) - the middle value of the data set, ie that divides the data set into two (50% of data values are lower, 50% higher).
The quartiles on which the ranges are based are a nice way of conveying the distribution of data in a simple, unbiased, representative way (often more so than the mean average and standard deviations). A 'box and whisker' plot is the usual way of displaying such data. For those unfamilar with such plots, the boundaries of the central "box" are the 1st and 3rd quartiles - the 25th and 75th percentiles. The box span between those quartile boundaries thus contains 50% of all values - by my definition, this is designated the "medium" range of pickup data values here. The line through the box is the median average. The ends of the 'whisker' lines show the furthest ACTUAL data values that are WITHIN limits designed to exclude outliers in such plots (lower outlier limit: Q1-1.5*IQR; upper outlier limit: Q3+1.5*IQR). All individual outlier data points that fall OUTSIDE those whisker limits are also shown. If you are particularly interested in the pickups that have those extreme high or low values, you can look up those particular displayed values in antigua's database to find those pickups. I could have added 'very high' and 'very low' categories for those outlier values, but elected not to. Since the whisker limit values are the smallest and largest actual data values that are NOT deemed outliers, "almost all" data thus lies between the whisker limit values (if normally distributed, > 99% of values would lie within those outlier limits). The max and min values can be seen on the plots too, and are tabulated below with the median and ranges.
Specifically ...
If you see any errors, or have any other suggestions, please let me know. Would also be good to hear how these ranges correspond to peoples' perceptions of what they thought the ranges might be for pickups in general, and particular pickups specifically.
