Post by frets on May 4, 2022 11:53:20 GMT -5
Hi Guys, I am having trouble with the following diagram. I’m getting a “cut out” of the pickups when the phase is pulled up. Can a good soul lay eyes on it to tell me how to fix this? Thank you!😸😸😸
Post by Deleted on May 4, 2022 13:15:53 GMT -5
I can't see any problem with the phase
(B-N), (B-N)+M, M, M+(N-B), (N-B) (B-N)xM, M, M, M, (N-B)xM
Using the " - " to show blend When M linker in series 2nd, 3rd and 4th position short the series bit so just Middle on its own
So example (B+N)xM when set the blend at max.
Post by frets on May 4, 2022 13:44:59 GMT -5
That’s what I see but it’s cutting out the pickups when the phase is engaged. I’ve checked the wiring and I have it exactly as seen in my diagram.
Post by frets on May 4, 2022 14:04:28 GMT -5
To be more specific, pulling up on the Tone (phase) by itself causes positions 2,3, and 4 to go dead.
Post by Deleted on May 4, 2022 23:11:06 GMT -5
My thinking is maybe it's grounding some how.
Put the prob on ground and touch each side of the pickup in both stages. I think when down just one side will be grounded and when up both sides will be grounded.
If that is the case , it might be easy to just redo the phase switch than track the fault down. Hope it isn't damage inside the switch
Post by frets on May 5, 2022 15:09:00 GMT -5
No, it’s not the switch. I can’t find it. Can somebody else put eyes to my diagram and help me out? I hate to ask and I hate to be such a pest but I really don’t get why this is not working. It just a simple phase switch. I appreciate it.’
Post by frets on May 5, 2022 15:30:01 GMT -5
Never mind…. I figured it out. The diagram is fine. I was using a Solderless terminal and had the Bridge, Middle and Neck grounded wrong. Thanks! And special thanks to Angellahash😺😺😺
