Post by electricgeek on May 10, 2022 13:39:24 GMT -5
Hey folks I'm trying to wire up a mini amp in guitar to be able to switch my output between mini amp,mini amp and output and headphone out to output to use mini amp effects. I've came up with a diagram useing two mini on on switchs but wondered if anyone knew of a one switch option I could use to not have so many switchs since my guitar already has so many things on it I would post pic of my diagram but haven't figured out how to post pics yet lol new here
Post by newey on May 10, 2022 14:21:11 GMT -5
eg- Hello and Welcome to G-Nutz2!Instructions for posting images are found here: guitarnuts2.proboards.com/thread/8198/new-instructions-on-image-postingIt is unclear to me exactly what you want here. The miniamp is going to be mounted inside the guitar, correct? And you want to be able to switch the guitar's output jack between the miniamp signal, regular signal, and a headphone output? Is the headphone jack already in the guitar, or are we talking about a headphone jack from the miniamp?
Post by thetragichero on May 15, 2022 18:35:48 GMT -5
i would wire the output jack direct and just worry about switching the other stuff. i wouldn't assume you'd pick up an appreciable amount of noise from the output jack acting as an antenna inside the guitar (assuming you've shielded things which i think would be necessary with an internal amp anyway)
