Post by thetragichero on Jun 15, 2022 16:08:50 GMT -5
picking up a schecter guitar this weekend for about the price i can flip the aftermarket pickups for. so, basically free guitar. i have an active bridge pickup for it (Duncan designed version of the mick thomson blackout), might install a sustainer in the neck because i don't have a neck pickup for it and because I've been wanting to do it for quite awhile (just need to find where my fargen coil wire got to in the move) one thing I'm not sure on: what to use for the tone pot hole. not a big fan of the standard cap abs pot tone control in my metal tele (even after using appropriate values for active pickups) so I'm soliciting options. i feel frets and MattB especially might be helpful one thought i had was buffer into a modified big muff tone control (values tweaked for that mids) into recovery gain stage into passive volume control. would the buffer be needed since I'm not using passive pickups? other idea is a little more extreme (but could work well with a metal guitar): basically distilling the gyrator eq stages from the boss heavy metal pedal to one knob so bass/treble boost and cut (I've got some nice s/w taper center detente pots that would work well here)
Post by frets on Jun 15, 2022 19:19:04 GMT -5
Trag, What about a nice onboard EQ circuit? I think this could be distilled into an onboard - maybe.
Post by thetragichero on Jun 15, 2022 19:42:34 GMT -5
really just looking for something using one knob since that's what it's already drilled for
Post by MattB on Jun 16, 2022 9:45:40 GMT -5
one thought i had was buffer into a modified big muff tone control (values tweaked for that mids) into recovery gain stage into passive volume control. would the buffer be needed since I'm not using passive pickups? other idea is a little more extreme (but could work well with a metal guitar): basically distilling the gyrator eq stages from the boss heavy metal pedal to one knob so bass/treble boost and cut (I've got some nice s/w taper center detente pots that would work well here) You can (sort of) do both. This is two Big Muff tone controls on a dual-gang pot, centred at different frequencies. SW1 flips one of the gangs backwards. With SW1 up, you get a mid scoop/mid boost. With SW1 down you get something similar to a regular Big Muff tone control, but with a mid boost instead of a cut. These graphs were made with a 0dB input, volume at 100% and tone stepped in 20% increments. Increasing R9 and R16 to 47k would give you about 5dB more gain.
This is still very much a work in progress. I haven't spent a lot of time trying to fine-tune it. I did add C3, R5 and R12 to try and balance things out a little better. It was going to be a two knob tone control for a fuzz pedal, but I haven't had time to work on it. I think there's plenty of room for improvement, but it could be a lot of work to get something worthwhile. Here's a simpler option. This is a fairly basic treble boost/cut. It uses a combination hi-pass/low-pass filter, with the idea being that you can increase brightness without adding too much fizz.
And here's the same circuit, with C5 reduced to 1n. The high end roll off is less extreme, and the range of the pot is shifted upwards. You have a bit more boost and a lot less cut available.
Post by thetragichero on Jun 17, 2022 18:51:03 GMT -5
MattB did you do that schematic in some sort of spice program? just downloaded kicad to figure out how to make a pcb on the little cnc (i have a bunch of copper clad g10 board from tayda) and figure not having to put in the whole thing would be easier for me (lazy)
Post by MattB on Jun 18, 2022 11:03:18 GMT -5
MattB did you do that schematic in some sort of spice program? just downloaded kicad to figure out how to make a pcb on the little cnc (i have a bunch of copper clad g10 board from tayda) and figure not having to put in the whole thing would be easier for me (lazy) Yes, I built it in LTSpice. Here is a copy of the simulation file: Version 4 SHEET 1 2008 680 WIRE -1360 -624 -1584 -624 WIRE -1136 -624 -1360 -624 WIRE -1136 -592 -1136 -624 WIRE -1584 -528 -1584 -624 WIRE -1136 -496 -1136 -512 WIRE -1136 -496 -1232 -496 WIRE -1008 -496 -1136 -496 WIRE -1232 -480 -1232 -496 WIRE -1824 -464 -1920 -464 WIRE -1360 -448 -1360 -624 WIRE -1136 -448 -1136 -496 WIRE -1920 -400 -1920 -464 WIRE -1584 -368 -1584 -464 WIRE -1360 -368 -1584 -368 WIRE -1232 -368 -1232 -416 WIRE -1232 -368 -1360 -368 WIRE -1136 -368 -1232 -368 WIRE -1824 -224 -1824 -464 WIRE -2032 -160 -2192 -160 WIRE -1920 -160 -1920 -320 WIRE -1920 -160 -1968 -160 WIRE -1872 -160 -1920 -160 WIRE 16 -144 -96 -144 WIRE 272 -144 96 -144 WIRE 672 -144 272 -144 WIRE 272 -128 272 -144 WIRE 672 -128 672 -144 WIRE -1920 -112 -1920 -160 WIRE -1824 -112 -1824 -128 WIRE -1728 -112 -1824 -112 WIRE -1584 -112 -1664 -112 WIRE -1488 -112 -1504 -112 WIRE -1424 -112 -1488 -112 WIRE -1024 -112 -1424 -112 WIRE -96 -112 -96 -144 WIRE 848 -112 848 -192 WIRE 944 -112 848 -112 WIRE 1088 -112 1024 -112 WIRE -1424 -96 -1424 -112 WIRE -1024 -96 -1024 -112 WIRE -432 -48 -432 -128 WIRE -336 -48 -432 -48 WIRE -192 -48 -256 -48 WIRE 272 -32 272 -64 WIRE 432 -32 272 -32 WIRE 544 -32 512 -32 WIRE 672 -32 672 -48 WIRE 672 -32 624 -32 WIRE -1424 0 -1424 -32 WIRE -1392 0 -1424 0 WIRE -1024 0 -1024 -16 WIRE -1024 0 -1232 0 WIRE -1488 16 -1488 -112 WIRE -1920 32 -1920 -32 WIRE -1872 32 -1920 32 WIRE -1824 32 -1824 -32 WIRE -1824 32 -1872 32 WIRE 944 48 944 -16 WIRE -2192 64 -2192 -160 WIRE 848 64 848 -112 WIRE 912 64 848 64 WIRE 1088 80 1088 -112 WIRE 1088 80 976 80 WIRE 1104 80 1088 80 WIRE 1248 80 1168 80 WIRE 1424 80 1328 80 WIRE 480 96 480 16 WIRE 720 96 480 96 WIRE 816 96 784 96 WIRE 912 96 816 96 WIRE -1280 112 -1280 48 WIRE -784 112 -1280 112 WIRE -336 112 -336 48 WIRE -432 128 -432 -48 WIRE -368 128 -432 128 WIRE -192 144 -192 -48 WIRE -192 144 -304 144 WIRE -96 144 -96 -48 WIRE -96 144 -192 144 WIRE -560 160 -736 160 WIRE -464 160 -496 160 WIRE -368 160 -464 160 WIRE 1424 176 1424 80 WIRE 272 208 272 -32 WIRE 672 208 672 -32 WIRE -464 240 -464 160 WIRE -1424 256 -1424 0 WIRE -1024 256 -1024 0 WIRE -2192 352 -2192 144 WIRE -1872 352 -1872 32 WIRE -1872 352 -2192 352 WIRE -1488 352 -1488 80 WIRE -1488 352 -1872 352 WIRE -1424 352 -1424 336 WIRE -1424 352 -1488 352 WIRE -1024 352 -1024 320 WIRE -1024 352 -1424 352 WIRE -784 352 -784 192 WIRE -784 352 -1024 352 WIRE -336 352 -336 176 WIRE -336 352 -784 352 WIRE 64 352 -336 352 WIRE 272 352 272 288 WIRE 272 352 64 352 WIRE 672 352 672 272 WIRE 672 352 272 352 WIRE 944 352 944 112 WIRE 944 352 672 352 WIRE 1424 352 1424 256 WIRE 1424 352 944 352 WIRE -464 544 -464 320 FLAG 64 352 0 FLAG -1360 -368 0 FLAG -1360 -624 VCC IOPIN -1360 -624 Out FLAG -336 48 VCC IOPIN -336 48 In FLAG -432 -208 VREF IOPIN -432 -208 In FLAG 944 -16 VCC IOPIN 944 -16 In FLAG -1824 -464 VCC IOPIN -1824 -464 In FLAG -464 544 VREF IOPIN -464 544 In FLAG 816 176 VREF IOPIN 816 176 In FLAG 848 -272 VREF IOPIN 848 -272 In FLAG 1424 80 OUT IOPIN 1424 80 Out FLAG -1008 -496 VREF IOPIN -1008 -496 Out SYMBOL cap -1440 -96 R0 SYMATTR InstName C1 SYMATTR Value 3.9n SYMBOL cap -1040 256 R0 SYMATTR InstName C2 SYMATTR Value 6.8n SYMBOL res -1040 -112 R0 SYMATTR InstName R1 SYMATTR Value 39K SYMBOL res -1440 240 R0 SYMATTR InstName R2 SYMATTR Value 22K SYMBOL ZZZ\\potentiometer\\potentiometer\ 2 -1216 -16 R90 SYMATTR InstName U1 SYMATTR Value Rt=100K set=1 SYMBOL cap 256 -128 R0 SYMATTR InstName C3 SYMATTR Value 22n SYMBOL cap 656 208 R0 SYMATTR InstName C4 SYMATTR Value 22n SYMBOL res 656 -144 R0 SYMATTR InstName R4 SYMATTR Value 39K SYMBOL res 256 192 R0 SYMATTR InstName R5 SYMATTR Value 8.2K SYMBOL ZZZ\\potentiometer\\potentiometer\ 2 416 -48 M90 SYMATTR InstName U2 SYMATTR Value Rt=100K set=1 SYMBOL voltage -2192 48 R0 WINDOW 123 24 44 Left 2 WINDOW 39 0 0 Left 0 SYMATTR Value2 AC 1 SYMATTR InstName V1 SYMATTR Value SINE(0 .75 1000) SYMBOL res 112 -160 R90 WINDOW 0 0 56 VBottom 2 WINDOW 3 32 56 VTop 2 SYMATTR InstName R10 SYMATTR Value 1.2K SYMBOL res -1936 -416 R0 SYMATTR InstName R9 SYMATTR Value 3.3Meg SYMBOL res -1936 -128 R0 SYMATTR InstName R11 SYMATTR Value 2.2Meg SYMBOL res -1840 -128 R0 SYMATTR InstName R12 SYMATTR Value 22K SYMBOL voltage -1360 -464 R0 WINDOW 123 0 0 Left 0 WINDOW 39 0 0 Left 0 SYMATTR InstName V2 SYMATTR Value 9 SYMBOL cap -112 -112 R0 SYMATTR InstName C6 SYMATTR Value 2.2µ SYMBOL res 640 -48 R90 WINDOW 0 0 56 VBottom 2 WINDOW 3 32 56 VTop 2 SYMATTR InstName R13 SYMATTR Value 47K SYMBOL res -1296 -16 R90 WINDOW 0 0 56 VBottom 2 WINDOW 3 32 56 VTop 2 SYMATTR InstName R14 SYMATTR Value 39K SYMBOL cap -1600 -528 R0 SYMATTR InstName C7 SYMATTR Value 22µ SYMBOL ZZZ\\OpAmp\\TL072 -336 144 R0 SYMATTR InstName U3 SYMBOL cap -496 144 R90 WINDOW 0 0 32 VBottom 2 WINDOW 3 32 32 VTop 2 SYMATTR InstName C9 SYMATTR Value 22n SYMBOL res -448 -224 R0 SYMATTR InstName R17 SYMATTR Value 10K SYMBOL res -240 -64 R90 WINDOW 0 0 56 VBottom 2 WINDOW 3 32 56 VTop 2 SYMATTR InstName R18 SYMATTR Value 33k SYMBOL cap 784 80 R90 WINDOW 0 0 32 VBottom 2 WINDOW 3 32 32 VTop 2 SYMATTR InstName C10 SYMATTR Value 22n SYMBOL res 832 -288 R0 SYMATTR InstName R19 SYMATTR Value 10K SYMBOL res 1040 -128 R90 WINDOW 0 0 56 VBottom 2 WINDOW 3 32 56 VTop 2 SYMATTR InstName R20 SYMATTR Value 33k SYMBOL res -480 224 R0 SYMATTR InstName R24 SYMATTR Value 2.2Meg SYMBOL res 800 80 R0 SYMATTR InstName R25 SYMATTR Value 2.2Meg SYMBOL res -1152 -608 R0 SYMATTR InstName R15 SYMATTR Value 27K SYMBOL res -1152 -464 R0 SYMATTR InstName R16 SYMATTR Value 27K SYMBOL cap 1168 64 R90 WINDOW 0 0 32 VBottom 2 WINDOW 3 32 32 VTop 2 SYMATTR InstName C8 SYMATTR Value 4.7µ SYMBOL cap -1248 -480 R0 SYMATTR InstName C11 SYMATTR Value 22µ SYMBOL ZZZ\\potentiometer\\potentiometer\ 2 -800 96 R0 SYMATTR InstName U5 SYMATTR Value Rt=50K set=1 SYMBOL ZZZ\\OpAmp\\TL072 944 80 R0 SYMATTR InstName U4 SYMBOL res 1408 160 R0 SYMATTR InstName R7 SYMATTR Value 1Meg SYMBOL res 1344 64 R90 WINDOW 0 0 56 VBottom 2 WINDOW 3 32 56 VTop 2 SYMATTR InstName R8 SYMATTR Value 470 SYMBOL res -1488 -128 R90 WINDOW 0 0 56 VBottom 2 WINDOW 3 32 56 VTop 2 SYMATTR InstName R21 SYMATTR Value 1.2K SYMBOL cap -1504 16 R0 SYMATTR InstName C12 SYMATTR Value 15n SYMBOL cap -1664 -128 R90 WINDOW 0 0 32 VBottom 2 WINDOW 3 32 32 VTop 2 SYMATTR InstName C13 SYMATTR Value 2.2µ SYMBOL cap -1968 -176 R90 WINDOW 0 0 32 VBottom 2 WINDOW 3 32 32 VTop 2 SYMATTR InstName C5 SYMATTR Value 22n SYMBOL njf -1872 -224 R0 SYMATTR InstName J1 SYMATTR Value J113-real TEXT -1816 408 Left 2 !.Ac oct 100 40 10000
This file doesn't include the 100n power supply bypass cap. I've never used Kicad so I'm not sure if this is what you're looking for- let me know if you want something different.
Post by thetragichero on Jun 19, 2022 20:37:36 GMT -5
don't know how to easily import into kicad so i'm putting the schematic in manually. suppose it's good practice learning a new tool. will be exciting if i can start to make my own pcbs
Post by thetragichero on Jun 20, 2022 11:01:02 GMT -5
laying out something this complicated to pcb for my first attempt is a bit daunting, and now that i see physical component size i think it might be a bit too big for control cavity but the general idea got me to thinking: buffer -> some sort of tilt/big muff tone control -> switch to put it into either the inverting or non-inverting op amp input to get either a mid cut or mid boost (although i suppose this would need three poles to switch the RC and CR filters to opposite ends) still kicking stuff around obviously
Post by thetragichero on Jun 20, 2022 20:39:27 GMT -5
this is what i came up with. would've liked flat mids to be a few db lower but oh well now to try to work up a board layout. any issues seen please let me know!
Post by Yogi B on Jun 21, 2022 0:10:52 GMT -5
this is what i came up with. would've liked flat mids to be a few db lower but oh well Using a larger tone pot and/or lowering R8 would lower the volume at the centre of the sweep. If you want this to apply only when the flat mids selected, obviously this would need to be added to the toggle switch (this might not necessarily mean the requirement of an extra pole). In order to match the flat mids plot you posted, it seems that R5 should be 33k not 10k. Also I don't see the point of R3, plus at its present value of 10k it'll interfere with the tonestack — it should to be larger, 100k or more, to prevent that. If it is even needed at all.Edit: that last part is the consequence of my brain pre-breakfast, please ignore. (Though, to be clear, I still don't see the point of R3.)
Post by thetragichero on Jun 21, 2022 9:06:15 GMT -5
you are correct and i have fixed my schematic
Post by Yogi B on Jun 21, 2022 16:31:34 GMT -5
Here's a further tweaked version, and although some values are changed it's the same number/type of components (however the toggle switch is upped to a DPDT): Which results in the following curves (red: flat-mids, yellow: scooped-mids): Changes: - As mentioned above Sw1 is now a DPDT (it is still depicted in the flat-mids position).
- C1 upped to 47n, this makes the flat response no lower than −1dB down to approx. 36Hz (with 22n it's 66Hz, which would be fine for standard tuning, but based on your mid-notch frequency I assume you're downtuning?).
- R3 (15k) & C4 (68n) have been repurposed to adjust the LPF in flat mode, somewhat upping the cutoff frequency & keeping the level of bass boost roughly consistent. In scooped-mids their effect should be minimal, though there could still be a better way to switch them out of the circuit.
- Additionally, since C4 was previously the coupling cap, I should mention that such a cap should no longer be required — the only voltage DC coupled to the tone stack is Vref.
- R6 is upped to 5k6 to compensate for the fact that it is switched in parallel with R5 (33k), rather than replacing it. (5k6 and 33k in parallel = 4k79.)
- R7 (33k) is repurposed as an extra loading resistor, switched in parallel with R8 (220k) when set to flat-mids.
- R9 is raised to 36k in order to lower the gain of the recovery stage and overall result in approximately unity gain at the flat setting.
- Oh, and finally, I've swapped the tone pot (RV1) to be the 'correct' way around — treble-boost/bass-cut when turing towards "10".
Post by thetragichero on Jun 21, 2022 22:16:37 GMT -5
figured out pcb routing in kicad and have installed the windows version of flatcam (linux version kept giving me errors related to some python-pyqt4 package that does not seem to exist. i have pyqt5 but even changing the python script to reference pyqt5 threw the same error. so windows32 version in wine it is) to turn my gerber and drill files into gcode. got my board and drill lined up and mirrored but i can't make the g code until i get the machine settings from my dad i'll note the change to 47nf whenever i make and populate the board got the bridge pickup installed (straight to jack) and temporarily soldered just to test, guitarcenter order arrived with a bunch of packs of strings. had a $10 off coupon so i got a bunch of things to try on various guitars. this one got dr ddt 12-60 tuned to c# minor chord. guitar is setup and i'm digging how this plays for a $3-400 new guitar, sounds killer into the modified jet city picovalve i keep in the shop (amp is a little darker than i'd like but that means when i push it with a dirt pedal it sounds really really nice) will post a picture here from my phone. the neck right now is an empty pickup shell... whenever i figure out where my coil wire is packed that'll be a sustainer with i guess another pcb. empty hole is getting a kill switch, will determine where my two switches go when it's time to install em (space will be at a bit of a premium) edit: and here's the guitar edit 2: looking at the board it appears i may have lost a couple traces when i had to move them all from the front side (which i won't have) to the back side of the board. at least i've got part of the process figured out
Post by thetragichero on Jun 21, 2022 23:35:28 GMT -5
okay much happier with this and the less white the faster this will cut
Post by Deleted on Jun 21, 2022 23:42:47 GMT -5
Still a few bits that are a bit too close for my eye site
Bottom left feels a bit near the pad
Top middle there is a ring around a square pad
Bottom right a earth point going via two pads near to each other when you have a bigger opening just to the left of it Also there is a angle track , I'd do it near the opening to avoid errors.
Top right some pads look like they are just touching the track
Right middle there is a square pad and then a round one that doesn't seem the round pad is connected to any thing
Post by sumgai on Jun 21, 2022 23:55:41 GMT -5
trag,
Put R3 back on U1a's inverting input. Reason being, it's intended to minimize quiescent current, the effect of which is that when a signal comes in on the non-inverting input, a small but noticeable offset, sounding like a blip, can occur.... and usually does. This is due to the current mirror in the two input circuits that are never quite exactly the same, there's always some microvolt or microamp difference in there. Even at unity gain for this stage, the blip might become noticeable later in the circuit.
In U1b, you have the same thing going on, but here we see the feedback resistor working in tandem with the "calming" resistor to form a voltage divider, which in turn creates a form of gain control. You currently have it set to a gain factor of 10. But at these values, a fair amount of current is flowing through the op amp, and not doing anything for the good of the signal. I suggest that you replace them with something like Yogi suggested, a 100K or better for each half of the TL072, and for U1b, try a 820K or 1MΩ resistor. Less current consumed, about the same gain factor.
Post by thetragichero on Jun 22, 2022 0:35:34 GMT -5
Still a few bits that are a bit too close for my eye site Top middle there is a ring around a square pad Right middle there is a square pad and then a round one that doesn't seem the round pad is connected to any thing these are either me not knowing kicad well or whatever, the 9v input has the ring around the pad and the two unconnected pads are the signal input
Post by Deleted on Jun 22, 2022 5:52:04 GMT -5
so is this going to be done by CNC or Etching , ever way you only use the TOP layer of a PCB can you not use the Easy EDA software and just use the Top layer Gerber File It lets you download the Gerber file so you can use it Easy EDADoing on CNC then you really want to fill in the gaps and just do like a Anti PCB i did work with a guy making PCB for me using a CNC (smart guy knew what i was doing making "Encoders")
Post by Yogi B on Jun 22, 2022 6:07:28 GMT -5
Put R3 back on U1a's inverting input. Reason being, it's intended to minimize quiescent current Now that you mention it, I think I've previously read about this in some general op-amp article, somewhere. However I've never seen it discussed in a guitar-audio context, and as far as I'm aware I've only ever seen this done once (potentially by accident) and that's in the Klon. I'll also admit I was slightly getting ahead of myself, I was already thinking about tying R5/R6 to Vref: thus eliminating the DC path to ground (and arguably that, by itself, represents a bigger reduction in current draw) and simultaneously providing the same function as R3 (the combination of R4, RV1 & R5/R6 amount to a resistance of 133k7 or 166k between the inverting input and Vref). Finally, I don't know how trustworthy it is, but ltSPICE says that there'd be more current draw with R3 than without.
i'll note the change to 47nf whenever i make and populate the board With your version both the input cap (C1) and coupling cap (C4) would need to be larger — and since there are two, both need to be about double the 47n I used (i.e. 100n) in order to be equivalent.
Post by thetragichero on Jun 22, 2022 10:16:01 GMT -5
thanks for all the suggestions folks. i've tidied up the layout and like this a lot better!
Post by Deleted on Jun 22, 2022 11:09:44 GMT -5
how you going to turn this on and off, because as it is and looks even when the guitar is unplugged it will drain the battery
Post by thetragichero on Jun 22, 2022 11:21:38 GMT -5
active pickup so the battery ground isn't connected unless a cable is plugged into the trs jack. these are taking the place of the passive tone and volume that would normally be in the guitar (volume is still passive but you know what i mean)
Post by Deleted on Jun 22, 2022 12:41:52 GMT -5
Ah right yes, so the - on the battery hooks up with the Ground only when the Jack is in
I think i'll have a look at desiging this circuit at the weekend some thing to do. and I'll try one for CNC (less cuts)
Post by sumgai on Jun 23, 2022 0:06:08 GMT -5
Finally, I don't know how trustworthy it is, but ltSPICE says that there'd be more current draw with R3 than without. That's exactly correct. But the thing is, the current you're speaking about here is that which is used to progress the signal long its path. In my original post, I was speaking of the quiescent current. Your idea of increased resistance is not only good, it's pretty much in line with the original chip designers' specs. It's, once again, a trade-off - more current draw versus a potential artifact disrupting the signal. I've not done much research of low-frequency (audio) op-amps in the past few years, but even a decade ago, there were much better quality op-amps available. I'm sure that the state of the art is by now quite capable of dropping a substitute part in place of that TL072, and making the (R3) resistor more-or-less unnecessary. But speaking of trade-offs..... at what cost? HTH sumgai
Post by thetragichero on Jun 23, 2022 8:29:44 GMT -5
currently fighting with cnc that seems to be more interested with dive-bombing its bit into the board than cutting it. might be awhile to have enough patience to troubleshoot
(in the interim I've almost completely cleaned up a gibson br-9 lapsteel and amp so i should get around to making a video of it today)
Post by Yogi B on Jun 25, 2022 10:04:45 GMT -5
Finally, I don't know how trustworthy it is, but ltSPICE says that there'd be more current draw with R3 than without. That's exactly correct. But the thing is, the current you're speaking about here is that which is used to progress the signal long its path. In my original post, I was speaking of the quiescent current. Actually I meant both, quiescent or otherwise. As you previously mentioned, even with no input the op-amp output will be a few mV different to Vref, so connecting a resistor between the two dissimilar voltages will obviously cause a current to flow. LTspice reckons 330nA with the 10k resistor (i.e. a 3.3mV difference).
I've been reading around, looking for an explanation as to the cause of effects you describe, or at least acknowledgement that this specific issue exists — so far that search has come up lacking. What I have seen is the problem of needing to account for input bias current (I think this is actually what I was remembering having previously read about). The bias current causing additional voltage drop to the input signals thus increasing the offset of the output voltage. As the TL07x family has FET inputs, thus relatively low input bias current (65pA @ 25°c), this effect isn't that major (even if we had 1Meg source impedance, the voltage caused by input current would be 65pA × 1MΩ = 65μV). Also, notably, the 'fix' isn't: to provide 'extra' current via a resistor (with your implication that a lower resistor would always yield better performance, at the cost of greater current draw), but rather to match this voltage drop for both inputs; and with a non-inverting buffer the way to do that across the whole signal cycle isn't connecting a resistor from the inverting input to an AC ground (e.g. Vref), but rather connecting the resistor in the feedback loop. (Nor have I found any mention that this problem could lead to audible artefacts of the kind you describe.) An alternative issue I saw mentioned is that when driving heavy loads, the output of some op-amps may degrade to class-B (or worse) operation, causing cross-over distortion. This seems to better fit your description of a "blip" occurring upon the onset of an input signal. The suggested solution for this is to essentially force the op-amp into class-A operation via drawing significant output current even in the quiescent state. And the simplest way to achieve that obviously being a resistor — but a pull-up/pull-down resistor, connected from the output to either of the power rails, i.e. not connected to Vref.
