aj9
Post by aj9 on Jun 17, 2022 18:39:50 GMT -5
Post by ashcatlt on Jun 17, 2022 21:12:54 GMT -5
The difference between split and parallel wired humbucker is kind of subtle. The parallel will tend to be slightly brighter, but maybe not so’s you’d know the difference unless you actually a/b them. The big difference will be that the parallel connection maintains the hum-cancelling, so there will probably be significantly less noise that way. The scheme you posted is as good as any other if that’s what you’re shooting for.
aj9
Post by aj9 on Jun 19, 2022 22:15:22 GMT -5
Appreciated
