Post by CheshireCat on Jul 21, 2006 9:26:02 GMT -5
OK, Chesh - your UUSS mod has me totally converted. Just one question... is it possible to put in a master tone pot? ie: one that can roll off treble one way and bass the other, and acts on the complete signal out of the guitar, rather than just from an individual pickup? And where would said tone pot be wired in? (ok so that's more than one question ) Such a pot, if it existed, would be coupled with the vol pot, which is where all those arrows on the Mode Switcher (and the + from the N) point to ("To Vol -->"). Tho, actually, I don't use a tone pot, master or otherwise . . . I use EQ!! ;D Specifically, EMG's BTC and VMC circuits. Believe me when I say, if you want monster tone, and monster tone control, those'll definitely be worth your while. Chesh
Post by spitfire23bc on Jul 23, 2006 10:33:08 GMT -5
Tho, actually, I don't use a tone pot, master or otherwise . . . I use EQ!! ;D Specifically, EMG's BTC and VMC circuits. Believe me when I say, if you want monster tone, and monster tone control, those'll definitely be worth your while. I presume that would be tricky to do with a single pot though!? I'd probably rather just go for the simplicity of a single tone pot. If it's possible to have a master tone, then great; if not, any suggestions as to what would be the best use of the pot?
Post by CheshireCat on Jul 23, 2006 13:29:42 GMT -5
Tho, actually, I don't use a tone pot, master or otherwise . . . I use EQ!! ;D Specifically, EMG's BTC and VMC circuits. Believe me when I say, if you want monster tone, and monster tone control, those'll definitely be worth your while. I presume that would be tricky to do with a single pot though!? I'd probably rather just go for the simplicity of a single tone pot. If it's possible to have a master tone, then great; if not, any suggestions as to what would be the best use of the pot? Well, first off, the EMG circuits are stupid simple to install and use. You get 12dbs boost and cut for Bass, Treble, and Sweepable Midrange, plus you can set the treble that you want on the BTC. Now, if you find some days you just want some treble-bleed more than others, then all you need do is just roll off the treble a bit, just like with a regular tone control. As far as the best use of a single pot, well, don't know. There's really nothing special about a tone pot that I can recommend. I've never been impressed with them. If you just want regular vol/tone, then just use regular vol/tone. If you want to save on control spots, you could even build them on a concentric dual pot, so you get both controls in one space. Apart from that I'm not sure I understand your question. Chesh
Post by spitfire23bc on Jul 24, 2006 4:53:14 GMT -5
Sorry - I think the reason my question wasn't clear is that I'm not too sure on what options are available! Using just a single pot (it'll be a push-pull, so I can use it for splitting one of the pickups in the UUSS scheme, so dual-concentric is out), is it possible to wire in a tone control that works for any combination of pickups? (ie: not like the standard strat tone controls that work on only one pickup each) How would this pot be connected to the superswitch? If such a control isn't possible, how would I connect a strat-style tone control (for, say, the neck pickup) to the superswitch? (Presumably it's a little bit ambitious to hope for a single pot to control both treble and bass?) Hope that clarifies things!
Post by CheshireCat on Jul 24, 2006 6:17:24 GMT -5
Sorry - I think the reason my question wasn't clear is that I'm not too sure on what options are available! Using just a single pot (it'll be a push-pull, so I can use it for splitting one of the pickups in the UUSS scheme, so dual-concentric is out), is it possible to wire in a tone control that works for any combination of pickups? (ie: not like the standard strat tone controls that work on only one pickup each) How would this pot be connected to the superswitch? If such a control isn't possible, how would I connect a strat-style tone control (for, say, the neck pickup) to the superswitch? (Presumably it's a little bit ambitious to hope for a single pot to control both treble and bass?) Hope that clarifies things! So, I gather we are going for a stock look? Alright, basically, you don't attach the tone pot off of the SuperSwitch, or any of the other switches for that matter. If you want a master tone control, that's easy. It just hangs off of a vol. pot, which is pretty standard. See if this or this makes any sense. Chesh
Post by spitfire23bc on Jul 25, 2006 13:15:51 GMT -5
So, I gather we are going for a stock look? Yes, plus the two toggle switches. Alright, basically, you don't attach the tone pot off of the SuperSwitch, or any of the other switches for that matter. If you want a master tone control, that's easy. It just hangs off of a vol. pot, which is pretty standard. See if this or this makes any sense. Chesh Perfect!! Thanks, Chesh I'm away for three weeks or so from tomorrow, so I'll be getting the parts and putting it all together when I get back
