Post by johnnycrash on Dec 12, 2006 15:20:46 GMT -5
I'm interested in using the 5-way Superswitch or "Megaswitch" purely as a tone control with set caps on the switch. Position one would be no tone caps, and pos 2-5 would be darker and darker... sort of like a bastardized Esquire switching in a way. Any clue how to do this? I've looked at StewMac's layout for the 5-way Super, but I'm pretty damn stupid -- I have three individual volume controls to blend in or out all three pickups and I'd like the 5-way switch to be the "tone control".
Post by ChrisK on Dec 12, 2006 18:07:24 GMT -5
This might help.... guitarnuts2.proboards45.com/index.cgi?board=schem&action=display&thread=1158705194It shows the layout of the super switch. With it being an exposed lever switch, one can easily see the switching just by looking at the switch and cycling it thru its positions. It's a 4 pole, 5 way switch. This means that each of the poles selects 1 of 5 contacts per position. While one could use just one pole to realize the cap switching, it may be much easier from a wiring perspective to use two adjacent pole structures. This way, each cap could span the gap (0.5"/12mm) from one wafer to the next between like selected contacts, one pole's common (wiper) would go to the common pickup hot point from all volume controls, and the other pole's common (wiper) would go to circuit ground. In essence, the switch pole commons replace the traditional tone pot/cap connections.
