Post by ChrisK on Apr 4, 2008 19:30:24 GMT -5
Please note that the schematic for the Import Switch should be labeled 3 2 1 COM COM 3 2 1. Also, the schematic position numbering for the right pole is backwards. It should be 54321 and not 12345. " COM" means the same thing as " P", both of which are the pole common terminals.
Post by ChrisK on Apr 23, 2008 20:04:54 GMT -5
pete12345 indicates; Thanks for the tip pete12345, it appears that one can change the import switch for the desired mode.
Post by ChrisK on May 6, 2008 10:17:59 GMT -5
Post by ChrisK on Mar 18, 2009 19:45:57 GMT -5
Post by haydukej on Aug 3, 2014 20:10:48 GMT -5
A "simplified" drawing of the import switch (3-way) ChrisK references. "A" and "B" are the commons/outputs and are connected to a different lug as noted by the colors depending upon the position of the switch. Best of luck.
Post by kaustinwright on Aug 16, 2015 20:26:18 GMT -5
I found a strange 5 way strat toggle switch out of an 80s HM squier strat, and wasn't sure which lugs held continuity with the common lug, so I have created a color-coded diagram to show what I've found out just in case anybody comes across one of these. I couldn't find much information regarding this switch, much less find a diagram online. Any help with the model or maker of the switch would be appreciated. The switch is numbered, and only has one common lug, rather than the standard 2-lug design found on most switches. There is a globe at the upper right corner of the switch that has a hurricane looking S inside if that helps to determine anything.
