Post by ChrisK on Jun 28, 2009 16:33:40 GMT -5
Inductors for passive guitars. These are small signal audio coupling transformers. These are what Torres and others use for their mid-boost kits. Mouser Triad small signal transformersX L= 2piFH Inductive reactance = 2*3.14159*Frequency*Inductance (H). Inductive reactance = Inductance 2*3.14159*Freq(Hz) Assuming that the impedance (not resistance) is measured at 1 Khz, a 10K impedance transformer winding would have an inductance of 1.6 Henry. A 15K impedance transformer winding would have an inductance of 2.4 Henry. A 7K5 impedance transformer winding would have an inductance of 1.2 Henry. Assuming that both windings are used, the possible inductance could be four times that of one center-tapped winding. (Inductance is proportional to the square of the turns ratio.) Conversely, using one-half of a center-tapped winding would result in an impedance of 1/4 of the full winding.
Post by pablogilberto on Nov 13, 2019 20:40:35 GMT -5
Hello!
I'm interested with this mid boost mod for passive electronics.
I have 3 questions. 1. How do you wire the inductor? 2. How to choose inductor values? 3. Do you have updated link where I can purchase this?
Thank you!
Post by blademaster2 on Nov 14, 2019 12:35:30 GMT -5
I have used - in my own guitars - a 1000mH inductor to give a mid-cut in place of a traditional tone control (I sometimes call it a "fatness" control), but I have not tried it for mid-boost. This inductor was pretty costly because it was very small, but the older post on this thread identifies other devices that might be cheaper
As an alternative, for mid-boost I have a Hagstrom guitar that uses both a series capacitor and a shunt resistor (switchable on separate switches, and it has no tone control knob), which is simpler than using an inductor, although it might not give you as much boost as a second-order boost circuit could. Essentially you are using the inductance of the pickups themselves in conjunction with the capacitor/resistor.
Post by pablogilberto on Nov 15, 2019 3:33:26 GMT -5
Can you share the diagram?
What are the capacitor and resistor values so I can try them?
Thank you!
Post by frets on Nov 16, 2019 3:02:53 GMT -5
Post by frets on Nov 16, 2019 3:21:17 GMT -5
Post by blademaster2 on Nov 18, 2019 12:39:46 GMT -5
Can you share the diagram? What are the capacitor and resistor values so I can try them? Thank you! The Hagstrom II schematic shows this. The resistor is 12kOhm (if I read the writing correctly) and the capacitor is 3000pF. The "Mute" switch invokes the low-pass response and the "Tone" switch invokes the high-pass response. Personally I am not in love with the result when both are switched, but it does boost the mids (actually cuts the highs and lows to achieve a similar result). high quality image hosting
Post by Deleted on Nov 22, 2019 13:28:44 GMT -5
