Post by sbgodofmetal on Mar 29, 2011 2:09:17 GMT -5
thanks ash i finally completely understand why you were saying that many caps wouldn't work in your previous posts now after disecting a standard diagram i understand you can only get 3 caps at the most on a standard 5way but it will result in a mass increase of bass on pos, 2&4 thats not always a desired effect now if only i could find a way to move the tones at 2&4, to 4&5, and just have .050uf at pos3 without sacrificing the blade for another true DP5T rotary as my 'at home' diagram already has 2 in it
Post by sbgodofmetal on Mar 29, 2011 2:14:52 GMT -5
which i'm wondering if it could be pulled off by the 4pole 24 lug super switch, any ideas on wiring that son of a switch, this way: pos1, .022uf. pos2, .039uf. pos3 .050uf. pos4, .061uf. pos5, .089uf.
Post by newey on Mar 29, 2011 5:34:18 GMT -5
You don't need the full superswitch, the 2P5T "half superswitch" would do equally well, you don't need the extra poles. I was working on something similar with a superswitch a while back, but as I recall I had to redo the diagram and never followed up on it. I'm surprised Ash hasn't mentioned his Ric yet, which has both V and T controls 'hard-wired". He also posted sound samples in, ahh, the "Sounds Samples" board.
Post by sbgodofmetal on Mar 29, 2011 8:11:24 GMT -5
well like i posted earlier the mega(GN2's1/2 a super) has 2poles but 7lugs, 5 are sources and 2 are commons right? going by stewmacs diagram i'd say that lugs 3&6 are the commons though i'd like to belive it'd be the 2 outer lugs but going my way its: lug1- common, lug2-.022uf, lug3-.039uf, lug4-.050uf, lug5-061uf, lug6-.089uf, lug7-common
Post by sbgodofmetal on Mar 29, 2011 8:34:31 GMT -5
also are you familiar with the ''double barrel'' strat mod? ?
Post by newey on Mar 29, 2011 8:34:18 GMT -5
The "half Superswitch" is different than the Megaswitch. The "half Superswitch is, literally, just that- one wafer w/ 2 poles instead of the full Superswitch which has 2 wafers, 4 poles. The Megaswitches from Stewmac are known as "Schaller Megaswitches" and are also available from EYB in the UK. Various other retailers carry them stateside. I misspoke earlier when I said that the Megaswitch "E" gave the original Strat positions- that one is the Megaswitch "S" model. The "E" model gives the regular Strat selections except that it gives N+B in the center position, instead of middle only as on a regular Strat. This gives one the "Tele-ish" sound. Here's a description of the "E" model from EYB: Megaswitch "E"While I was wrong about the specifics of the Megaswitch E, it is still not a regular 2P5T switch like the half-Superswitch. All of the variuous Megaswitch versions are designed to give specific pickup combinations via easy "wire-by-number" protocols. To use one of these for what you want will require working out the switch logic. This can be done based upon the view of the switch internals.
Post by newey on Mar 29, 2011 8:45:21 GMT -5
AFAIK, no one has yet posted the pinout diagram for the Megaswitch "E" model. Here's one for the Megaswitch "S" for reference; this will be somewhat different than the "E" model, but it does demonstate, to an extent, how these Megaswitches differ from a regular switch. guitarnuts2.proboards.com/index.cgi?board=modules&action=display&thread=5520And yes, I'm familiar with the "Double Barrel" mod, but I'm not sure what it is about it that relates to this topic. Someone built one a while back and we had a long discussion, use the search function and go back about 700 days and get about 50 posts, you should find the thread in question.
Post by sbgodofmetal on Mar 29, 2011 9:10:42 GMT -5
like said in my pm i got to thinking instead of a DP5T pup select w/a push pull neck add try the double barrel strat mod for even more pup options and sounds i realized after initial posting that the 2 outer caps on the blade are in the wrong spot so just switch them around and your good to go
Post by sbgodofmetal on Mar 29, 2011 9:27:37 GMT -5
using two true DP5T rotary's instead of 2 5way blades and dropping the tone control completely and using the p/p vol as a switch add... down pos,= switch #1 alone for standard 5 strat sounds... up pos,= switch 1&2 together for custom coil adding and wiring the old 5way blade as a 1/2 varitone using .022uf, .039uf, &..050uf caps and cap mixing at pos, 2&4, to gain .061uf & .089uf. giving you the stock 5 sounds &125+ different pup combo's and 5 different tones to play them through its one massive tonal beast
Post by sbgodofmetal on Mar 29, 2011 9:36:42 GMT -5
pro's: no invasive routing or drilling required so guitar appears externally 'STOCK'. addition of a 5way tone blade gives you 2 standard strat tones and 3 additional tones for a bigger variety of sound. the use of a p/p allows you to toggle 2nd pup switch on &off for standard 5 in down pos, & 125+ on the up pos,
Post by sbgodofmetal on Mar 29, 2011 9:48:26 GMT -5
cons: the loss of the tone control means when you select a tone thats it you're unable to adjust its levels without losing the guitars volume since its wired directly to the volume, its not always 'practical' to go through 125+ switch settings to get the sound you want (unless you memorize what you like or draw a switch pos, chart) using the volume pot as a p/p can often get in the way causing abstruction while strumming (this can be avoided by simply moving the pot down the pickguard) cont....
Post by sbgodofmetal on Mar 29, 2011 9:56:07 GMT -5
the 5 tones on the blade are not in a true assending order pos, 2&4 have a mass bass add with pos4, being the heaviest of the 2 those values are pos2, .061uf & pos4, .089uf(where pos, 1,3,& 5, are in true assending order i'm currently workig on a way to fix the assention order so bare with me on this issue)
Post by sbgodofmetal on Mar 30, 2011 8:08:17 GMT -5
I've been thinking? (Yeah, yeah, I know.) about taking my ver. of the double barrel mod and making the 2nd pup selector a DP6T to get the 5 sounds plus a bypass effect. and making the up pos, of the p/p a passive O.D. add!!! giving it further more sound possibilities
Post by ashcatlt on Mar 31, 2011 11:18:41 GMT -5
I'm surprised Ash hasn't mentioned his Ric yet... Boy howdy, have I got rotaries! In fact, all of my electric 6-strings have them. The Rick has 6 altogether - 4 x DP5T, a 4P5T, and a 4P3T. My first post here was re: my 3 Humbuckers, no Pots Strat which has 3 x DP5T as well as the 5-way blade I described at some point earlier. My MiniStrat has 2 x DP5T on top of 3 x DPDT toggles. My LP never got a thread of its own, but it's got a DP5T in place of the Gibson toggle. It's currently just Master V and T, but I've been thinking about adding a rotary to get some "broadbucker" options. Not sure what to do with that fourth hole... Then I've got a DP5T in my Rodent for different clipping options. I built a Volume/Tone/Buffer into a Crybaby shell which has a DP5T to change the input impedance, but it's not working currently. I think I may have found a solution, but... Okay, I lied! There is the Behringer Strat which I re-wired back to standard because I was going to sell it. Now that I've stuck a nut extender on it for lap steel type stuff, I think I might change some stuff. Maybe even experiment with 4real's sustainer thing.
