Post by JFrankParnell on Sept 26, 2011 19:59:58 GMT -5
yes sir, and absent a 3 or 4 pdt, that's just what I'll do. tanks!
Post by ashcatlt on Sept 27, 2011 0:19:54 GMT -5
I actually was going to make a new thread asking for explanation of how to affect individual pups with the tone. If by this you mean individual pickups within a combination, the simple answer is that you can't. That tone control will always affect all the pickups in any combination (where it is included) one way or the other.
Post by JFrankParnell on Sept 27, 2011 20:28:50 GMT -5
ok, I can get that. So, on a standard strat setup, when you are on N+M, both tones are affecting the sound? Would that be cumulative? I.e., If both tones are on 7, the resulting 'tone' might be 4?
I guess the non-simple answer is something to do with an active summing mixer.
Post by asmith on Sept 28, 2011 7:40:36 GMT -5
If you're using 250k linear pots, then "7" is 175k. The R total of the two pots is 87.5k, which is "3.5." If both tones are on 7, the resulting 'tone' might be 4? Round about.
Post by ashcatlt on Sept 29, 2011 17:17:22 GMT -5
Yup, and in series combinations with individual Tones you get that "broadbucker" thing where the highs from one pickup are rolled off while those from the other are allowed to bypass the first and the combination comes out brighter overall.
In parallel mode you can try to "hide" the tone controls (and pickups) behind a volume control or series resistor to reduce this interaction, but this has its own trade offs.
The active mixer thing, properly implemented, could fix the parallel issue. Won't work in series mode, though.
