Post by podunkphill1953 on Feb 22, 2007 20:11:02 GMT -5
Does anyone have the layout distances for a strat on the pickups from the nut to the centerline of the neck pickup and then to the middle and finally the bridge pickup? Theses measurements will help me in turning this tele into a three pickup Carvin type guitar. Will take the before and after pics since I will be fabing a new pickguard instrument panel out of aluminum diamond tread plate and repainting the body from butterscotch to a metal flake candy apple red. So the measurements for the pickup locations will help in moving this modification along. thanks Phill
Post by podunkphill1953 on Feb 22, 2007 22:51:08 GMT -5
I had posted this question in another area and after a lot of discussion sumgai was able to post the locations for me. thanks again Sumgia and thanks for your dedication to this forum. Phill
Anyhoo, the distance from the fret side edge of the nut to the middle of the magnet for each pickup:
Neck - 19 5/16" (490mm)
Middle - 21 11/16" (550mm)
Bridge - 23 3/4" (603mm) (low E)
Bridge - 24 3/16" (613mm) (high E)
