nexis
Post by nexis on Mar 14, 2006 21:22:25 GMT -5
Hello, I need some help to identify a guitar. Here's a picture of the body, front and back. I believe it's an Ibanez Saber. I need to find a neck for it. It supposedly had a 24 fret neck on it before. Thanks All!!! EDIT: Distance from the heal cutout to the tremolo posts center is--- 5 7/8" Neck heal cutout is--- 2 3/16" Tremolo posts center to center is--- 3" Body thickness is--- 1 3/4" in the center but the edges are about 1"
nexis
Post by nexis on Mar 15, 2006 23:18:11 GMT -5
Nobody knows what kind of guitar this is? Anyone heard of a brand called Wenson? I'm thinking it's a Ibanez Saber copy.
Post by mlrpa on Mar 16, 2006 0:09:06 GMT -5
IF it's a Sabre, it's made of mahogany and a 22 fret neck. If you want to check, measure the distance between the two humbuckers. then measure between the hums on a 22 fret guitar and a 24 fret guitar. Whatever it matches, it is.
jester700
Post by jester700 on Mar 16, 2006 7:03:41 GMT -5
That's no sabre, or even a copy. The sabre isn't so"carved", is much flatter, has the jack on the guitar face, and is 22 frets. That long pocket looks like a 24 fretter, as does the pup spacing. The neck pocket looks lighter than any mahogany I've seen; maybe alder, ash, or basswood.
Post by flateric on Mar 16, 2006 10:00:51 GMT -5
Definitely looks like some kind of Ibanez to me.
nexis
Post by nexis on Mar 16, 2006 13:25:42 GMT -5
I believe it's basswood. Maybe from Dragonfire Guitars?
jester700
Post by jester700 on Mar 16, 2006 14:50:28 GMT -5
It's Ibanez-ISH, but it's not Ibanez. The trem rout would match their Edge - the good one. So that means a high end guitar. But the crooked trem pad, low end pivot bolts, and standard square neck joint say "midline or below". Plus, the outline is RG, but they don't make carved bolt on RGs.
nexis
Post by nexis on Mar 16, 2006 19:46:37 GMT -5
Here are some more measurements... EDIT: That 2 3/4" Measurement for the heel is supposed to be 2 3/16"
