HBD Three Holer using Seymour Duncan P-Rails (neck/bridge)Runewalker has been after me for years to wire up the HBD on my Tradition Les Paul Gold Top, but I have been hesitant due the requirement needed to carve/hog out a bit of wood in the cavity so the 4PDT’s threaded bushings would protrude enough through the carved maple top to get a nut on them. With those concerns I decided to try the Three Holer HBD on a Str@t type guitar I own.
I used a Seymour Duncan P-Rails set, mainly because they have a full fledged P90 and a Single Coil Rail as the two coils of the humbuckers. The HBD is a good fit for these pickups. I had the Bridge P-Rails in this guitar already so I knew how it sounded … and I liked it. I picked up a neck SD P-Rails, P/P pots from StewMac, and the 4PDT’s, PUP selector, and the System Par/Serial switch from other assorted vendors and Rune’s stash. I was ready to proceed.
The HBD project was a bit intimidating on the front end, but it was worth every minute of work in my garage during chilly 100+ degree F Texas weather…. Iced beverages made the work process run a bit cooler along with an ice enhanced fan system.
The most baffling items to deal with were the P-Rails coil wiring codes (start/finish). The neck and bridge pups are coded differently per the P90/Rail coils. The SD support on these questions was fantastic on providing start / finish for each coil in each pickup. I basically had to translate the standard HB SD wiring code colors into the P-Rails Bridge/Neck P-Rails color codes. More on this a bit later.
In addition to the color coding conventions issues, SD decided to invert the polarities and winds in the Neck and Bridge versions. I suppose this was so that in N-single and B-single combos the humcancelling options would facilitate rail/rail and P90/P90 configs. Rune and I still debate the merits of that fixed set of choices. However if I had to I could invert the mag on one then try to keep the additional wire-insulation color conventions straight. Too much cogitation.
I mainly used solid core copper wire color coded with shrink wrap, which really made the wiring easier to follow. I only had one break per my finagling with the whole harness… mainly due to my soldering. Main hot and ground wires to the input jack are thicker stranded wire. For the Pickup selector, I opted for a mini paddle toggle versus a Fender type 3 way for space savings. (glad I did this)
I added the mini DPDT System P/S switch as well. Both of these were mounted in the "PUP selector slot" on the pearl pick guard. I also added a Concentric tone knob so both pups have separate tone controls.
Treble bleeds on both volumes were capacitors 1nF and resistors 150k (Thanks John and Rune) for the best balance. Tone caps were 0.022uF.
The 4PDT switches are mounted offset in relation to the Volume knobs. From a playing/sight perspective this makes them easily visible (not hidden behind the Vol knobs). They are also spaced properly to allow for ease of volume control manipulation. Ergo, configuration and accommodation for live playing are always a good ‘thang’. Pic is a view from a "playing perspective".
I did have to hog a bit of wood for the Neck Vol and the Bridge 4PDT to fit nicely in the rout, but not a lot. The PUP/Control cavity on various Str@t type bodies are always a bit different on each one I have worked on. The wood hogging required was not even close to the pick guard edge so all is hidden nicely. Pic is of the bottom 4PDT switch hogging required.
Here is the finished/patched conductive copper shielding. You can see where I had to cut out a bit of the bottom Bridge "ear" from the rout to snake the PUP cables to the controls.
Other hardware enhancements include steel saddles and a steel trem block (both Guitarfetish) which makes the bridge beefier (highly recommended). GraphTEK TUSC nut and string trees. Wilkinson tuners.
To finally get the pup wiring harness to fit properly, I had to remove a bit of the wooden “ear” from the bridge PUP routing cutout. This Str@t body had 3 separate cutouts for bridge, middle, and neck pups…not a bathtub rout. Careful usage of a sharp chisel made it a quick and clean job. The entire rout is shielded in conductive copper tape for zero to little hum (high gain settings only) when using the single coils.
The Str@t type body is alder I obtained from Rondo Music … not a high dollar boutique body, but it is a very nice body with good solid tonal characteristics. Neck is a Guitarfetish maple/maple. Again not boutique, but it contributes the snap I would expect from an M/M neck. My final planned hardware enhancement is to install steel 8/32nd threaded inserts in the neck along with stainless steel 1 ¾” – 8/32nd threads through the body to solidly attach the neck to the body. I have done this on one other guitar and the results were noticeable to my ears. Tuning is more stable as well and the neck is definitely more rigid. Regardless if one can hear the difference, it absolutely improves the “purchase” between the neck/body.
After Rune and I tested the”3 Holer HBD” during our July 4th “Firecracker Jam/Texas BBQ Fest”, we both agree the P-Rails set was an excellent fit for the HBD in that there are the two full fledged coils in each P-Rail (SC Rails.P-90) versus a standard slug/adjustable coil in standard Humbuckers. Each of these coils can stand on their own tonally and when switched to their HB modes they blast off in fine fashion. The serial HB is thick, meaty and clear. The parallel HB is clear, articulate, sonically substantial and a gas to play arpeggiated chords through. Sort of a chimey PAF.
I oriented the P-Rails with the P90’s outer and the SC Rails inner. Rune and I discussed this at length and concluded that the two inner SC’s together would yield better “quack” They do.
The outer P90 in the bridge is where I would have put it anyway. Monster lead blues tones.
Neck outer P90 has an excellent Jazz comping sound for chording. Your PUP orientation is a matter of your personal tastes. I could go on for a while about all the combos and the blending of each PUP to the other, but will spare you the verbage. With the right amp/stompbox/playing techniques, I have gotten credible Texas style Billy Gibbons, Eric Johnson, SRV, Freddie King, T-Bone Walker and other quality tones from this scheme.
I am totally astounded with the palette of tones available with the HBD/P-Rails combo. The HBD is an inspired wiring scheme and I hope many of you “Nutz” out there will jump on the bandwagon and join these two old Texas coots (runewalker and sonosonny). Others that have tackled this are DarKnight from Finland, FenderBender, and Zamzara.(UK). So this thing is international with British, Australian, Finland and that whole other country, Texas imprints all over it.
Sincerest kudos to Rune for his conceptual ideas and to John Hewitt for his time and efforts in the schematic/engineering part of this project. Maximum Karmic points for their work.
After you familiarize yourself and have been enjoying the HBD switching scheme (even en old cat like me can get it), then playing a standard Str@t or a standard Two HB 2.Vol-2-Tone configuration is like someone trying to convince you their beef chili is “spicy” because they used bell peppers and beans in it (both felonies in Texas).
I will play this build out live with no problem. The control options are easily learned and quite intuitive, since the direction and up or down positions inform you as to the configuration. But the harness and options are really exceptional in a recording environment. With the P-Rails, lots of SC, P90, HB sounds and PUP combinations to choose from that will inspire your composition and creativity. I am confident other conventional HB’s will shine as well.
Some hints for HBD Construction:Seymour Duncan P-Rails specific wiring codes---
NeckP90 – North Polarity
Start -- Black
Finish -- White
SC Rail - South Polarity
Start -- Green
Finish-- Red
BridgeSC Rail – North Polarity
Start -- Red
Finish -- Green
P90 - South Polarity
Start -- White
Finish -- Black
Standard SD Humbucker wiring CodesScrew Pole Coil– South Polarity
Start -- Green
Finish -- Red
Slug Coil - North Polarity
Start -- Black
Finish -- White
Dis-regard PUP connective wire color in the pics, just orient per your preferred Inner (start/finish) and Outer (start/finish) PUP specific wiring codes. Some “Nutz” will prefer different slug/adjustable coils on inner/outer….
LayoutPer layout on the 3 Holer HBD, I suggest attempting to replicate your cutout routing onto your wiring template or actual pick guard for accurate placement of all the switches. This may not eliminate having to minimally hog some wood, but at least you will be aware of the rout and switch placement. Awareness of the ergonomic switch layout while playing is also a consideration.
Wiring up the SD P-Rails with an HBD, made me think (ouch!) about these specific wiring components and I hope this info will help others.
Son O Sonny on GNuts2
